Headder questions
Old Mar 25, 2004 | 09:45 PM
hillbillyk's Avatar
hillbillyk
you can go to hedmans website and look up headers, they have them for just about every kind of 70's ford truck, 4wd and 2wd. I found my fenderwell headers there and ordered them through summit. Summit sells alot more parts then are listed in the catalog, those are just the most popular applications.
Old Mar 26, 2004 | 10:27 AM
kc5hwb's Avatar
kc5hwb
What are fender well headers? Is that the same as shorty headers?
Old Mar 26, 2004 | 12:06 PM
hillbillyk's Avatar
hillbillyk
fenderwell exit headers go over the frame rail and gets the exhaust outside the frame rail.
Old Mar 27, 2004 | 12:49 PM
Ford member's Avatar
Ford member
Research tells me any header designed for any 335 series engine will bolt onto each other.So you have more options 351c 400m and 351m .Therefore you may find 351c headers fit better only because they are different .fordsunlimited.com/tech/400mperformance.htm is the website I found this info.Good to know this because I found a set of headers on ebay and won the aution for 4.97 lol plus shipping
Old Mar 27, 2004 | 04:41 PM
Torque1st's Avatar
Torque1st
Posting Legend
Emissions equipment is determined by GVWR and model.
My 78 F250 with the same equipment had EGR but no smog pump or cats.
Old Mar 27, 2004 | 07:50 PM
kc5hwb's Avatar
kc5hwb
The route the headers take along the engine well and around the transmission I think is more of a concern. I have found alot of headers for my truck in 4WD only, which doesnt' help me cause mine's not 4WD. I think the reason for this is the transfer case. The headers would bolt to my engine, but would not route through my 2WD undercarage. That's my understanding....
