Sponsored by: Real Truck
F350 height with a load
Old Mar 15, 2004 | 08:16 PM
O2BaRN's Avatar
O2BaRN
How much will a F350 4X2 W/ 8' bed "squat" with a load of 1800 lbs in the bed?
The actual bed rail height is 55" without any load even though the Ford specs said it was 53". If I need to, can I lower the the rear any?
My 5ver is 58" on the over hang and I just want to make sure that I can tow a level trailer with enough clearance B/T rails and trailer.
Our new 04 F350 4X2 SRW 4.3 V10 is at the Ford dealer waiting for us to pick it up, but before I spend $30K I want to make darn sure it will be Ok.
Thanks
Dave
Old Mar 15, 2004 | 10:20 PM
Coro's Avatar
Coro
I'm not much help, but I'll pass on my experiance.
My 28 ft Montana (12,000 LB) has a hitch weight of about 2000 lb. The truck rear drops a few inches when I hook up, but I have not measured it. However the truck appears level when hooked up (titled forward a bit with no load).
To get 6 inch clearance on the rails, I have my Reese 15K Pro hitch (Pro series tilts both ways) set at full height. The fiver rides a few inches higher in the front than in the rear, but it is not noticible. I checked the weight on both 5er axles and it is the same, and the handling is fine (after adding a TrailAir pin box).
The 350 (4x4?) has 4 inch blocks on the rear axle, while the 250 has only 2 inch blocks. Some folks have swaped to the 2 inch blocks on their 350 just to lower it. I haven't seen a need, but it is nice to know the option existis.
Don't know if any of this is relevant.
Old Mar 15, 2004 | 10:29 PM
BASSER's Avatar
BASSER
I've got a F-350 s/c..with 11,200 springs, I had to get the 5th wheel trailer axles dropped 3 in ( trailer raised) to get it to set level, with enough clearance , not to hit the back of the rails..Still only have about 5 inches, instead of the required 6 inches. The truck didn't drop anymore than a couple of inches with the load. I pull a 37 footer
2001 f-350 super cab, dually--v-10 with 4;30 ls
Old Mar 15, 2004 | 10:34 PM
O2BaRN's Avatar
O2BaRN
Coro,
Thanks for the input. I can't pull my 9500# 5er with my 99 250 light duty 5.4 anymore, so I guess that I will get the new 350 and try to figure it out as I go. I can always run a bit high in the front like you do.
Thanks again for the help
Dave
Old Mar 15, 2004 | 10:43 PM
O2BaRN's Avatar
O2BaRN
Basser,
I have 3" clearance as it stands now without hooking up. I hope that once I load the truck with passangers, fuel and hitch plus the 1600+lbs king pin weight, it might give me 3 inches of drop.
I can't flip my axles because they are the torsion ones.
Even if I don't get the full 3" drop I can raise the hitch an inch or two and run a bit high in the front like Coro.
Thanks for the input this is helping me feel beter
Dave
Old Mar 15, 2004 | 11:31 PM
BASSER's Avatar
BASSER
Watch on the height, the more you raise the nose of the trailer the less weight on the hitch...could cause handling problems..
Jim
Old Mar 16, 2004 | 01:55 AM
Edmo's Avatar
Edmo
Originally posted by Coro
... Some folks have swaped to the 2 inch blocks on their 350 just to lower it. I haven't seen a need, but it is nice to know the option exists.
I had them swap my 4x4 Super Duty to the 2" blocks at the factory... They called it a F-250.
Edmo
