Help! Truck "jumping" when put into drive.
Old Mar 15, 2004 | 07:33 PM
AirSmitty's Avatar
AirSmitty
I have a 1975 f250 4x4 with a 360/c6. Whenever I put it in drive, it wants to jump into gear no matter how hard i press the brakes. The tranny seems to want to engage at too low of an rpm. Is there a way to adjust this?
Old Mar 15, 2004 | 07:44 PM
78fordman's Avatar
78fordman
Sounds like the t/c is staying locked up if the tranny has that feature. Might need a new torque convertor. There is a way to adjust the shift point, the detent cable goes down to the tranny. Are the shift points lower than normal?
Old Mar 15, 2004 | 07:51 PM
AirSmitty's Avatar
AirSmitty
It's shifting fine, and it idles fine when I'm stopped for a stop light, but when I shift it into drive it makes a jerk forward then dies if I don't let off the brakes. thanks
Old Mar 15, 2004 | 11:58 PM
Torque1st's Avatar
Torque1st
Posting Legend
The vacuum modulator may be bad or need adjustment. There is no cable on a C6. You may need some transmission work. I will move this thread to the tranny forum where the transmission experts are.
Old Mar 19, 2004 | 04:19 PM
460powerhouse's Avatar
460powerhouse
your torque con may be swollen i've seen that happen to a few ford torque cons the only way to fix is replace
Mtnhermit
Apr 30, 2016 12:57 AM
Nealcrenshaw
Jun 1, 2012 04:54 PM
theduke308
2004 - 2008 F150
Feb 1, 2012 12:01 PM
Boostcrazy99
May 4, 2011 07:58 AM
