351M missing at light excelleration
Old Mar 15, 2004 | 10:15 AM
faceplant's Avatar
faceplant
Unhappy 351M missing at light excelleration
I'm stumped. I have a 1978 F-150 with a 351M that misses during light excelleration. I have replaced the plugs, wires, computer module,fuel filter, distributor cap & rotor, put a carb kit in it, and taken all of the uneeded vacuum hoses off. I'm wondering if I need to jet it down. It has #57 jets in it and I'm at 1400 feet in elevation. Any suggestions?
Old Mar 15, 2004 | 11:31 AM
beartracks's Avatar
beartracks
You might check the vacuum and mechanical advances in your distributor.
Old Mar 18, 2004 | 11:19 PM
mark a.'s Avatar
mark a.
Try a known good carb.
Old Mar 21, 2004 | 12:19 AM
paragod's Avatar
paragod
did you check the correct vacuum hose routing? you said you pulled everything unneeded off, so be sure that you haven't crossed paths anywhere. also: base timing, fuel pressure, air intake? (may be dumb, but my Dad always said "check the simple s*** before you throw money at it.)
