Offroad & 4x4
Will 44's Fit?
Old Mar 17, 2004 | 10:39 AM
85351ho's Avatar
85351ho
do you know for sure superduty springs will fit? you need about 57 inches eye to eye for them to work. and those spring look like they will ride stiiiiif....not to mention youl have way to much lift. if you wanna clear those 42's with no cutting , then all you need is about 9 inches....
come on...you know you wanna cut
Old Mar 17, 2004 | 10:58 AM
ivanribic's Avatar
ivanribic
Yes, the sawzall calls to me in the night. I actually went out and bought the sheet metal tool for my air hammer, I think RLH suggested it but I'm just not convinced I want to chop it up. I'm thinking if I can lift enough to clear these and I decide to go bigger down the road I can just trim 2" off the fenders and I'll be ready to roll.
Crap, you're right. The SD rears are 56" but the fronts are only 51". I was looking at the wrong measurements. What brand springs are you throwing up front and what did they cost you? I'm definitely doing the shackle flip in the rear but not sure if I'll also need to buy new rear springs or not.
Old Mar 17, 2004 | 11:37 AM
85351ho's Avatar
85351ho
i jus tpicked up some skyjacker 4 inch rearts for 275 shipped from a guy, ill let you know how they do
Old Mar 17, 2004 | 04:45 PM
FordPickMeUp's Avatar
FordPickMeUp
42's that are 14 not bad im pretty sure with my 9 inches of lift they will fit.And i like that fact that there not to wide so the cops dont pull me over.if not those ill go with 44's but then i guess i will have to hack the fenders so we will see.
Old Mar 17, 2004 | 04:52 PM
85351ho's Avatar
85351ho
yea, i like narrower better, i bet the 42 iroks will handle great on the road compared to 44 tsls or boggers, mostly because they will be skinnier
ill be interested to see this truck when you get through
you may wanna look into puttin a 60 up front....its an easy swap
Old Mar 17, 2004 | 08:42 PM
fishmanndotcom's Avatar
fishmanndotcom
let me just add a thing or two here....the width that is posted is the tread width! i have 13.5's but the actual tire is 14.5" and the trwad width is 11" across. with the 42's the tread width is 15" which means the actual tire will be about 16-17 or so.....therefore you may still rub!
and yes the D60 swap is easy as hell! Ho and I did mine one afternoon!
-Jason-
Old Mar 17, 2004 | 10:27 PM
ivanribic's Avatar
ivanribic
I don't get the width on the Interco tires. If the 13.5 on your tire is the tread width then why are yours only measuring 11"? Interco lists a tire width and seperately lists tread width. The STS are listed at 21" wide with a tread width of 15.5. I've seen them before and the tread is definitely not 21" across, though the tire has some serious side bulge that would contribute to the total width.
I'm going to go ahead with the 42s because everything I hear about the IROKs is good. I love the way they look too. Wouldn't be able to sleep at night if my tires weren't just a little bigger than Jasons.
Old Mar 17, 2004 | 10:29 PM
85351ho's Avatar
85351ho
13.5 isnts supposed to be the tread width, thats the width of the whole tire, i.e the carcass....thats the way it is with all tires
mone r still bigger than both of yall
Old Mar 17, 2004 | 10:38 PM
ivanribic's Avatar
ivanribic
Shut yo mouf ho . . . or I'll be an idiot and buy the 49s!
I thought that was the total measurement. I wonder if Fishy's are just a little wider with weight on them.
Old Mar 17, 2004 | 10:43 PM
85351ho's Avatar
85351ho
dont make me get those 5 tons and 60's ive been wanting
tire specs usually aint right on wut they are supposed to be, especially width...cuz air pressure and rim width make a difference
Old Mar 19, 2004 | 12:18 AM
FordPickMeUp
when they coming out with those 42" IROKs?..I went to tthe site and all it says is coming soon.
Old Mar 19, 2004 | 02:22 AM
ivanribic's Avatar
ivanribic
I heard mid April. Their site still says the radials are "coming this spring" but NTW has them for sale . . . though I haven't called to ask if they're in stock.
Old Mar 19, 2004 | 08:32 AM
  #28
85351ho's Avatar
85351ho
ive noticed over the years that interco's site is a low priority for them to keep updated
Old Mar 19, 2004 | 09:56 PM
  #29
proeliator's Avatar
proeliator
Yea, their sight is the last place you want to go for updates. The tingleing in my left leg tells me that they will be available in around a month, if not sooner. Interco is really pushing for their iroks. Got the rags pimping them like hell...
Old Mar 20, 2004 | 09:44 AM
  #30
85351ho's Avatar
85351ho
i wish they would come out with a 44x14 or 15 bogger
