Not that I do not mind buying add ons but does anyone see any potential problems with modifing the stock air box , I drilled about 1 1/4 holes in a honey comb shape all around the box and installed a K & N filter. Seems to work,, I do here a wistle like sound when I im the 3 to 4000 RPM range.
you want cool air entering the air box, hot air cost hp, I have seen it on dynos several times, guys that leave the first half of the air box off and have a K+N sticking out of it are actually hurting hp, if that K+N addes 3hp then you are lossing 4-5hp from the heat, I would buy a REAL cold air induction or make a good heat shield. Good idea though, if you look around a little you can make your own ram air or something.....
Almost forgot, you need to disconect the battery for at least 20 min. to re-program the ecm, you are now bringing in a lot more air, the computer needs to know this, it will adjust the fuel and timing to take advantage of this more air-fuel-timing=more power!
Originally posted by SMiller
...it will adjust the fuel and timing to take advantage of this more air-fuel-timing=more power!
The changes it makes are so small that you'll never feel it. Plus, I find it hard to swallow that the computer will alter timing because of holes in the air filter housing.
I know I should have stated that were talking 0.02hp gains, but the computer does need to learn of your adjustment, so the computer does need to be reset.
Fresh cool air makes power, so no matter what you do just make sure it is getting cool fresh air, and lots of it. It looks like the K+N filter charger kits have a heat shield for that reason. Any time you do something that alters anything that has to do with the engine the computer needs to be reset, even if you have a chip or programmer or anything.
