Sponsored by: Auxito
4X4 light staying on
Old Mar 14, 2004 | 09:21 PM
nex813's Avatar
nex813
I am having a problem with my 4X4 and Low geat lights staying on. Just to let everyone know, I have to use 4 wheel drive to get in and out of my drive this time of year (mud). When I leave home and the truck is still cold, the light will go out, but when I get home, or the truck is warm, that's when the lights stay on. If I just put it in 4 hi then that light just stays on, but if I use 4 lo, then they both stay on. If I let the truck cool down for a few moments, then they're off (I always put it back it 2 hi when I park it no matter when or where I park it). Anyone have an idea? Can't find anything in the hayne's manual. Thanks
Old Mar 14, 2004 | 11:29 PM
Racerguy's Avatar
Racerguy
I would probably try replacing the 4x4 lockout switch on the transfer case. It is on the front of the transfer case above the front driveshaft. I'm not sure why they call it the lockout switch but that's what Ford calls it. It is the switch that sends the gear position signal to the light on the dash. When you remove the switch see if there is any moisture in it. If there is you should also replace the transfer case oil. Actually if the oil hasn't been changed before it might be a good idea anyway.
Old Mar 15, 2004 | 10:44 AM
nex813's Avatar
nex813
OK. I'll change both the switch and the oil. I planning on doing all the oil as soon as I get a nice day to do so. Thanks for the advice.
Old Mar 15, 2004 | 07:04 PM
Racerguy's Avatar
Racerguy
Let us know how it goes please.
rjorg
Electrical Systems/Wiring
17
Mar 30, 2023 06:02 PM
Mike Brackins
All Things Towing
Aug 22, 2015 05:24 PM
Mike Brackins
Jul 13, 2015 08:49 PM
BIGWORM936
Sep 15, 2014 11:52 AM
id_birdhntr
Jun 5, 2013 10:57 PM
