Bronco II Ford Bronco II
Emissions HELP!!!
Old Mar 14, 2004 | 08:42 PM
colbyg311's Avatar
colbyg311
Emissions HELP and Upper valve train noise.
I've got a 1987 bronco II, it's a two wheel drive with a 2.9L V6 engine. It is giving off emissions and I can't get rid of them. The truck was wrecked two years ago and hasn't moved since then. I recently decided to fix it. I have replaced the driveshaft, the air filter, the fuel filter, I cleaned all the bad oil out and put new oil in it and I changed the oil filter.. I've changed all the plugs and the plug wires, and I've also changed the pcv valve, but I can't get rid of these emissions, what do I need to do to get rid of them? It is also making a winding noise and when I accelerate it gets louder. I've been told it is an upper valve train noise, but I wasn't told what to do to get rid of it. What do I do?
Old Mar 15, 2004 | 10:17 AM
Ken00's Avatar
Ken00
Welcome to FTE!!!
What test did you fail? Have you tried pulling the codes, see the tech info post, pulling eec-iv codes.
Does it sounds a little like a jet engine, if it does it could be a bad fan clutch.
Old Mar 16, 2004 | 11:25 PM
hazzard64's Avatar
hazzard64
you didnt say what part of emmisions it failed, but when mine did, all i did was replace the air filter,i cleaned out the housing of it too, and ran it about 5 to 10 min on the freeway, and it passed no problem, try it. i dont know about the winding nois though.
