Bronco II Ford Bronco II
tires
Old Mar 15, 2004 | 02:55 PM
shadower's Avatar
shadower
Exclamation tires
Does anyone know how big of tires i can get without getting a lift on an 87 Bronco 2, also would it be safe (not tip)? How much would the price range be or should it be?
Old Mar 15, 2004 | 09:56 PM
mrshorty's Avatar
mrshorty
Depends in part on how much rubbing you can tolerate. I'm running 235/75R15, and they just don't rub. Any bigger, and they would rub under certain conditions. Some have been satisfied with 30/9.50 and I suspect there might be a few that get away with 31/10.50.
Old Mar 15, 2004 | 10:24 PM
geowolf's Avatar
geowolf
235/75R15 here. plan on goin to a 31/10.5 and crossin fingers
Old Mar 16, 2004 | 08:53 PM
shadower's Avatar
shadower
Now do having those size of tires have any potential of tipping on a normal turns in the roads at lets say 50 miles an hour?
Old Mar 16, 2004 | 11:17 PM
mrshorty's Avatar
mrshorty
Note that those size tires are not only taller than stock, they are also wider than stock. It's not scientifically determined, but I don't think simply putting a larger tire on will significantly change the "tippiness" of the truck.
Old Mar 17, 2004 | 01:37 AM
BroncoIIFool's Avatar
BroncoIIFool
This is true as the 30/9.50 are the biggest you can truly get away with without trimming the fenders..
Do a little Fender Trimming though, and those 31/10.50's will fit no prob, and will actually "help" with what little rollover chance there is by giving you a wider "stance"..
Busted ol' 85
Feb 11, 2010 02:15 PM
Extacie
13
Apr 11, 2009 12:12 AM
cjben
General Automotive Discussion
19
Dec 12, 2006 07:41 PM
umdstang
2004 - 2008 F150
17
Mar 11, 2005 03:37 PM
Longneck
Mar 10, 2004 02:30 PM
