1997 Explorer Problems, Need Advice
Old Mar 14, 2004 | 04:33 PM
Dhathaway's Avatar
Dhathaway
Question 1997 Explorer Problems, Need Advice
I have a few problems that need to be taken care of before I will sell this vehicle. It has a roaring problem in the MAF and I have been told that I need to replace it with another one. Another problem is a leaking oil pan gasket I believe. There is a light bit of oil on the front side of the pan, hoping it isn't from the crankshaft seal. I am pretty sure that it is an oil pan seal problem, I haven't noticed any loss in fluid, it is probably very minimal. One other problem is the water pump that I replaced last summer, it apparently has a very small leak around the housing seal. I thought I had cleaned the old gasket material very well and sealed it back properly and even torqued the bolts around the water pump adequately.
Let me know your thoughts on these subjects.
Thanks!
