No start 88' 5.0
It started about a week ago, I was driving through a intersection, turning right, and as I put the accelerator down my truck just bogged like I was getting no fuel. I let off the gas and she went smooth to idle. Again, I laid into the accelerator(smoothly) and bogzilla. I drove straight home but noticed that if I tried to give her too much throttle she would bog down like she was gonna die if I didn't let off. Problem seemed to go away while troubleshooting in the driveway. Sounded too much like a tps, so I changed it and cleaned out the throttle body. Nope. Not it. Just yesterday it did it again, after driving a few miles- too much throttle-truck would bog down. Hmmmmm. Let's put some fresh fuel in her belly. And after I gave her a slight rev with the clutch in to announce the arrival to the gas station, it happened. My truck died. Well AAA just lost some money on me! So off I went looking for a fuel problem. Aha, the fuel filter is old and dirty. Nope. So, here I am looking for a most likely fuel problem but now it looks like I have no spark. Fuel pump runs and pumps fuel(checked it when changing filter ). I have fuel in the fuel rail. I'm using the fresh tank of fuel(dual tanks). I pulled a spark plug and tried to get spark at cylinder then at coil. Tried both the jacob's ignition and then patched in the original coil---no spark. I'm in the middle of wrestling out the ignition module off the distributor but the little bugger has some off sized deep well bolts. I'm frustrated and am about to "remove" the module via caveman style. Any suggestions before I overlook something? Prethanks, 4x.
