Replacing spark plugs??
Old Mar 14, 2004 | 10:24 AM
golfboy17's Avatar
golfboy17
I have a 92 explorer, and i dont know when the plugs and wires were replaced last lookning old so am going to do it, the problem is the passenger side how do i get those 3 plugs out and the wires off the plug the drivers side looks ez, do i need any specail tools or anything am goign to do the wires as well
Old Mar 14, 2004 | 12:01 PM
maa139's Avatar
maa139
The only one that's difficult is the in the back. Don't even thing about getting to that one from under the hood. Go through the wheel well. Other than that it isn't a difficult job. No special tools are needed, but if the wires are as old as you say, they may put up a fight.
Old Mar 14, 2004 | 02:50 PM
golfboy17's Avatar
golfboy17
so i would have to remove the platice piece in the wheel well, is it ezer to do those 3 through the wheel well, or just the one
Old Mar 14, 2004 | 04:08 PM
maa139's Avatar
maa139
I just did the one through the wheel well, and I didn't remove the plastic piece. I just used the exhaust manifold as a reference and felt around for the plug. The front two should be pretty easy to get to from the top.
Old Mar 15, 2004 | 02:13 PM
golfboy17's Avatar
golfboy17
I have one more quick question what is the size of the socket you used on the spark plugs? Also i'll ussume you used some extensions for the one you have to get in the wheel well how long? I just wanted to see if i could get the wires off of one spark plug i could with a little bit of twisting and pulling it came right off. Also is there anyting else i should replace while am doing this
Old Mar 15, 2004 | 04:12 PM
maa139's Avatar
maa139
5/8 I think. And I don't remember if I used a 3 or a 6 inch extension.
Old Mar 16, 2004 | 08:45 AM
nhfire 77's Avatar
nhfire 77
Dont forget to put anti-seize lubricant on the Spark plug threads. If you dont, when the next time you change the plugs they might not want to come out and play. If you dont mind spending a few extra bucks get a spark plug socket, it has a small rubber insert built into the inside of the socket designed to cushion the plug and makes life easier.
Old Mar 16, 2004 | 12:20 PM
golfboy17's Avatar
golfboy17
Yea thats what i was going to get, craftsmen has a one with a flex head figure i get that one for the passenger side plugs it would be a little ezer, i will get the anti sieze stuff for the threads as well, hopefully it was put on these plugs so they will come out ez, also what kind of plugs would you recomend
