Tire/Gears
Old Mar 13, 2004 | 07:24 PM
JackyJay's Avatar
JackyJay
Tire/Gears
I'm thinking about putting 31's or 32's on my 96 explorer and I've read that one should regear gears to 4.10. Is this true/needed? BTW: This truck is my daily driver that wants to see some offroad. Thanks
Old Mar 13, 2004 | 07:52 PM
Pig Pen Jr's Avatar
Pig Pen Jr
Even if you have 3.55 gears, 31s or 32s will not be bad. Yes regearing is a good idea and will help with gas milage and power, but if you don't have the cash now and you want the tires, gears can wait. I ran 33x12.5s with 3.73s and it was my DD. I had no problems and gas milage only went down about 1 or 2 mpg.
Old Mar 13, 2004 | 08:52 PM
351ballsofford's Avatar
351ballsofford
what's the diff. between 3.55 and 4.10 because i'm told to get the 4.10's i'm also using 3.55. is it bad to run big tires and 3.55 other than gas mileage?
Old Mar 13, 2004 | 09:07 PM
Pig Pen Jr's Avatar
Pig Pen Jr
Here is a chart that shows what size tire and what gears are best to be run with that size.
http://www.4wheelparts.com/Tirel_Gear_Ratio.asp
It is all about keeping the RPMs down or at least at a good level. The taller the tire the "taller" the gears. As your tire size goes up, the gear ratio should go down(even though the numbers actually go up). I'm not good at explaining it and i hope someone who is better at it will chime in...
Old Mar 13, 2004 | 09:12 PM
351ballsofford
thanks for the chart and the effort i think i get the picture but if someone would chime in that would be cool too
Old Mar 13, 2004 | 09:15 PM
351ballsofford
heres the link where i found some gears recommended by mustang http://store.summitracing.com/defaul...both&part=4.10 do i need the RMG-6903101? those are the ones i think.
Old Mar 13, 2004 | 09:19 PM
Pig Pen Jr's Avatar
Pig Pen Jr
Those look to be what you need, but I don't know what you are putting them in. I assume the 150 that is listed in your signature. I got my gears for my Bronco II from Randy's Ring and Pinion, but that is a good price on 4.10s.
Old Mar 13, 2004 | 09:20 PM
JackyJay's Avatar
JackyJay
96 gear ratio?
What is the stock gear ratio on a 96 Limited Explorer AWD?
Old Mar 13, 2004 | 09:21 PM
Pig Pen Jr's Avatar
Pig Pen Jr
Where in IA are you from/ I was born in Cedar Rapids and go back there very month...
Old Mar 13, 2004 | 09:22 PM
Pig Pen Jr's Avatar
Pig Pen Jr
JackyJay - it could be anything from 3.55 to 4.10... you need to check the tag on the rear diff or check your door jamb sticker for an axle code.
Old Mar 13, 2004 | 09:27 PM
351ballsofford
des moines my fellow iowan.
Old Mar 13, 2004 | 09:28 PM
JackyJay's Avatar
JackyJay
I checked the sticker and it said D4.
Old Mar 13, 2004 | 09:29 PM
Pig Pen Jr's Avatar
Pig Pen Jr
We do offroad runs down to a place 20 min s of CR called 600 Acres. I'll send you an e-mail with the name of a site that you can register on and watch for our next run.
Old Mar 14, 2004 | 09:30 AM
351ballsofford
That's awesome send away.
