spark plug problem
Old Mar 13, 2004 | 06:08 PM
centex73's Avatar
centex73
Question spark plug problem
Hello to all. Awesome site, it has been very helpfull!
I bought my 72' F100 about a month ago. It has a 360 with a C6 tranny. I have been having a blast tinkering with it. I have recently put the pertronix ignition system in and love it! On to my question. When I changed the plugs I couldn't get the number 5 plug out. The socket won't go completely on the plug because it hits on the motor before it gets all the way around the plug. I am wondering if the wrong plug was installed? And how I am going to get the plug out?! Just hoping you guys had some ideas on this one? Thanks again for all the help!!
Old Mar 13, 2004 | 09:00 PM
fordpilot's Avatar
fordpilot
You may need a thin walled socket..you can get
them at most parts stores.
Old Mar 13, 2004 | 09:42 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Just my opinion!! that someone has put in a 5/8 plug in that hole
and your 13/16 hex socket is just going over it?
I cant remember if the 360s ever ran a 5/8s Plug??
But there will be one of the guru's here soon to correct me!!
Good Luck!! Russ!!
Old Mar 14, 2004 | 08:36 AM
centex73's Avatar
centex73
I will try the thin wall socket. Thanks!
Old Mar 14, 2004 | 07:31 PM
fordaholic-67F100's Avatar
fordaholic-67F100
could be that the corners are rounded off to. if so, use a junk metric socket 12 point and drive it on to the plug base. remeber you will destroy the socket, so get a cheap one to sacrfice. just a thought but is the socket hiting the top of the plug? I have seen some strange plugs out there and you might have one with an extra long insulator. hope you get it out. as far as what rapid russ said. I have not seen a 5/8 plug in a FE before either. but people do some strange things. can't wait to hear how this one turns out.
Old Mar 14, 2004 | 07:41 PM
fordaholic-67F100
Ok rapidruss. I could not stand it any more. I checked the Chiltons book I have, and it shows 1965 to 1976 BF32 and BF42. all the same 13/16 pulg size. still someone could have stuffed the wrong one in there.
Old Mar 15, 2004 | 06:39 AM
RapidRuss's Avatar
RapidRuss
Fordaholic!!! I have seen some wierd SH** back when I had my shop!! I had a guy come in 1 day with a miss in a 6 banger Pontiac..We could figuer it out and pulled the head.. someone had pulled the rod and piston out of one of the holes and welded a plate in that cylinder<--its to early to type?? LOL!!
Russ!
Old Mar 15, 2004 | 09:26 AM
jimshaver's Avatar
jimshaver
on the subject of the plugs... i know ford wnet to a 9/16" spark plug for 2004... not sure if it was on the v8 or the v10 or both ... the socket for these is probably in the $50 range.... your best best is youse a normal 9/16" deep socket to unthread it then use a magnet to pul it out.... at least if you cant aford or find the new socket.... even the dealerships dont have the socket yet
Old Mar 15, 2004 | 10:37 AM
73Custom's Avatar
73Custom
Is it dirt or a small pebble? I've had gravel around my plugs in the past - I drive a few miles of gravel roads every day. Get a good light and try to see what your socket is hitting.
Marty
Old Mar 16, 2004 | 07:23 AM
centex73's Avatar
centex73
It was hitting on the actual motor towards the bottom of the plug. The thin wall socket worked! Thanks Frank!!
Old Mar 16, 2004 | 10:08 PM
biz4two's Avatar
biz4two
Another success story! Cool!
Old Mar 16, 2004 | 10:54 PM
pward76's Avatar
pward76
At least it was on #5..
could have been worse - like #8, behind the booster and steering box!
Old May 8, 2004 | 07:48 AM
eriksf250's Avatar
eriksf250
I had a wierd incident with my plugs. I bought Bosch Platinum plugs for my truck and my truck won't start with them. I checked to make sure they are right and I gapped them right and they won't work. The funny part is that the old ones will still work.
Old May 8, 2004 | 08:22 AM
Ratsmoker's Avatar
Ratsmoker
Try chaning plugs in the edel heads. It is a 5/8" plug and you will need to go hunting for a cheap socket to get the walls thin enough. I hate it. I see no reason they couldn't have made the recess a little wider.
The platinum plgs don't work well in older non-efi engines and I can't give you a reason why. Plain old autolites seem to be the hot ticket. I used to think autolite plugs were like Fram filters but after hearing so much good stuff I tried them out. Its autolite for me from now on.
Old May 16, 2004 | 09:30 PM
eriksf250's Avatar
eriksf250
since i have a 352, and i know there's a lot of guys in here with 352s, i would like to know what kind of spark plugs they run and what their part number is so i can check them out.
