Sponsored by: Real Truck
Kodiak Steps
Old Mar 17, 2004 | 10:31 AM
Yeti's Avatar
Yeti
Tell you the truth, 8" seems perfect for me on my truck, it's actually a couple inches lower than my tubes were.
Only fell out twice before I got use to them.
Tell ya another thing, we just got 10" of snow last night and they collect it pretty good, I had little icebergs hanging off of them when I was done plowing.
Old Mar 17, 2004 | 10:43 AM
MrRottnDog's Avatar
MrRottnDog
They'll hit you another $100 a step for the 12" legs!
Old Mar 17, 2004 | 10:46 AM
Yeti's Avatar
Yeti
I can't see really needing the 12vers on a non lifted truck, right now, mine seem pretty much in the "middle" from the ground to the sill.
Old Mar 17, 2004 | 03:26 PM
renaissanceman's Avatar
renaissanceman
thanks for the info guy's. When I showed the link to LOML she went "OOOO-good". With that stamp of approval it's a forgone conclusion that a set will probably be THE FIRST accessory going on my new F-350. Hope there's a market for OEM running boards on ebay.
Old Mar 17, 2004 | 03:38 PM
DCSpecial's Avatar
DCSpecial
renaissanceman,
You also might want to look into the AMP Research Powerstep. They are the full length of the cab and are more like a running board. When the door is closed the are hidden up under the cab, but when you open the door the come down and out.
Hope this helps.
Old Mar 17, 2004 | 07:19 PM
renaissanceman
yeah - that looks even better as a step. Not much helpful info for consumer on the web page though - like how much and who sells them and who can install them?
Old Mar 17, 2004 | 07:39 PM
tatt2dwhytboy's Avatar
tatt2dwhytboy
I just called them a little while ago. You can get them from ford or a number of other shops from what I was told, dunno. The set of them should sell for about $1200, not including installation. Hope that might help.
Old Mar 17, 2004 | 09:28 PM
renaissanceman
thanks -
garryk6
Dec 13, 2012 07:45 AM
jimmyb08SD
2011 - 2019 Explorer
Oct 4, 2012 06:44 PM
hosemandc
Alaska Chapter
Aug 11, 2007 08:31 PM
hosemandc
1966 - 1977 Early Broncos
Aug 5, 2007 07:50 AM
JONNYB
6.4L Power Stroke Diesel
Feb 26, 2007 10:29 AM
