Will this work?
Old Mar 13, 2004 | 01:27 AM
kaotikedge_111100's Avatar
kaotikedge_111100
Will this work?
I am stranded out of town and I keep getting a dead battery. I figured out that the wires got ripped out of the alternator and I can't find where they were supposed to go. Can I run a postive from the ALT. straight to the battery and a negative straight to the frame?? Will this charge my battery and is it safe enough for a 200mile trip home?? Thanks so much for any advice!
Old Mar 13, 2004 | 09:47 AM
kaotikedge_111100
I've got to get this done asap, I'll make sure that a voltage regulator is hooked up before the cable is taken to the battery..but will it work or won't it??
Old Mar 13, 2004 | 10:14 AM
sparky's Avatar
sparky
One wire from battery + to Alternator "Bat" terminal.
One wire fron regulator "F" to Alternator "F" terminal.
That should get it working, as long as the regulator wiring is all hooked up.
See this link for a simple diagram.
https://www.ford-trucks.com/user_gal...=16603&width=0
Old Mar 14, 2004 | 02:34 AM
rebocardo's Avatar
rebocardo
From NAPA you can buy any connector, with the wires attached, to fit almost any American car or truck. They cost from $11-$18. You can buy connectors for the voltage regulator too. Sometimes Autozone has them, sometimes not.
You can buy cheap crimping tools, wire strippers, and connectors at Autozone for about $10.00 Total cost to get you going, under $30.00.
02Ford150
1997 - 2003 F150
Nov 3, 2012 12:39 PM
MRCKNLPS
Feb 28, 2012 07:55 PM
kyle j
16
Jan 5, 2012 12:25 AM
npccpartsman
Escape & Escape Hybrid
13
Jan 10, 2011 09:08 AM
4x4bigblock
Electrical Systems/Wiring
13
Feb 24, 2006 08:30 AM
