door ajar switch?
Old Mar 12, 2004 | 05:26 PM
Icicle's Avatar
Icicle
door ajar switch?
2000 7.3 PSD crew cab, door ajar light wont go out and all 4 doors are shut, I thought maybe the pin was stuck in, but I cant seem to find any, is there a switch inside the latch or something? Anyone who can tell me where the switch, or actuator for the switch is located, it would be very appreciated
Thanks
Kevin
Old Mar 12, 2004 | 06:23 PM
brwolfjr's Avatar
brwolfjr
i just had mine replaced under warrentee. it is apperently part of the latch. I have heard of guys spraying wd-40.
Old Mar 12, 2004 | 06:49 PM
jporter's Avatar
jporter
This is a common problem. The solution is to lubricate the switch mechanism.
My dealer did this under warranty, so I do not know how or where.
Old Mar 13, 2004 | 07:27 AM
powerstroker250's Avatar
powerstroker250
Spray all the latches with WD-40. Worked for me.
Old Mar 13, 2004 | 10:39 AM
Savaged1's Avatar
Savaged1
Hi Guys,
I had the same problem with my 2001 X PSD. I used WD-40 but after a few weeks it happens again, so I used the oil that you use for like a swamp cooler. Its water resistant and doesn't evaporate over time.
Old Mar 13, 2004 | 11:00 AM
bigblu250's Avatar
bigblu250
I had same problem w/my '01 250 4x4. Took it to dealer under warranty and they ended up replacing passenger side switch. It took them several attempts to replicate the problem because mine only acted up intermittently. Other than that this truck has been awesome! I will drive 'till the wheels fall off!
Old Mar 13, 2004 | 12:13 PM
ROK31_99PSD's Avatar
ROK31_99PSD
I am working thru this right now. I have tried the WD-40 trick but no dice. I am going to pull the whole door panel and see whats actually in there. One other odd thing is my remote door lock will not operate right now either, but I guess if the switch isnt made it wont work anyway. Sorry for the wandering off there, but has anyone pulled this apart themselves and looked at the switching mechanism itself. Gets old with lights coming on when they want to and door buzzers going off just any old time.
Old Mar 13, 2004 | 08:14 PM
farmb0y's Avatar
farmb0y
I've had that problem and had to replace both of my switches on the both doors. I've got a '99 F-350 so didn't have any warranty to cover it. It's not too complicated to fix. Figure out what door is causing the problem. You have to take your door panel off and will probably have to take apart your door latch to make it the easier to get to. The door ajar switch is part of the latch and is on the back, bottom side of the latch, so it is kinda difficult to get to with the limited amount of space in the door. You can get a new switch at most parts stores or the Ford dealer. I got my from a local mechanic and he had visual directions on how to take it out, like you have to turn it clockwise to get it out, and counterclockwise to lock it back in. Once I replaced them both I haven't had a problem yet. If you have any more questions, ask. Good luck with fixing it, cuz it's an annoying problem to have.
socalarcade
1983 - 2012 Ranger & B-Series
Dec 12, 2010 05:17 PM
01EX
Oct 4, 2010 09:33 AM
kenstacey
Mar 22, 2007 03:10 PM
Gcourville
Jan 2, 2004 06:45 AM
midc
Jan 28, 2001 08:23 PM
