Pulling Code
Old Mar 12, 2004 | 03:52 PM
upinhear65's Avatar
upinhear65
Wink Pulling Code
Hey can any one give me a clue on pulling codes.
Went to auto zone and had the guy pull codes but I think that he though my check engine light was on. He said that every thing came back ok. Is there another way to pull codes?
Old Mar 12, 2004 | 03:54 PM
acerockola77's Avatar
acerockola77
What year is your truck?
Old Mar 12, 2004 | 04:05 PM
hreed's Avatar
hreed
If the light isn't on, there may not be any codes to pull.
upinhear65's Avatar
upinhear65
2000 ext cap xlt 3.0
Old Mar 12, 2004 | 04:13 PM
hreed's Avatar
hreed
Your truck has the OBD II system and requires the use of a scanner to read the codes. Is the engine light on?
Old Mar 12, 2004 | 04:58 PM
upinhear65's Avatar
upinhear65
no it's no one butg I was just curious. i was having some idel problems change the plugs and wires and I'm reseting the computer as we speak. So I was wondering if I had some sensor problems that would show up on the codes. And yes I do have OBD II
Old Mar 12, 2004 | 06:25 PM
hreed's Avatar
hreed
Normally if there are any sensor problems, the CEL will come on and the computer will set the codes. There are some provisions in the OBDII system that will give you "pending codes", which means the computer is showing that something may be going wrong, but hasn't failed yet. See if you can find a code reader that will read pending codes. If you reset the computer by removing the battery terminal, you will lose any pending codes that may be stored.
Old Mar 12, 2004 | 08:42 PM
upinhear65's Avatar
upinhear65
thanks
Old Mar 12, 2004 | 09:17 PM
Ken00's Avatar
Ken00
If your having a problem with the idle I would try cleaning the IAC.
Old Mar 15, 2004 | 09:03 AM
upinhear65's Avatar
upinhear65
I've done that and cleaned my MAF. When I changed my spark plugs (motorcraft cooper) I broke a wire. Everywhere I went they have to order the plugs I need. Even Ford, so I went to Advance auto and they had a set of auto lites that I think my be causing the problem. I going to check and see if I can find a set of motor craft wires cheeper the what ford sells them for.
