Emmision problem
Old Mar 12, 2004 | 01:19 PM
Hottemp's Avatar
Hottemp
Emmision problem
I live in maryland and have to put my 1995 F-250 through the emmision test every two years. I have a 460 cid. motor. It failed the nitogen test and all the others were elevated. My truck has always passed with flying colors. I took it back for a retest with hi test gas and ran it on the hiway for along time first. It still failed. The truck runs great. Does anyone have a sugestion or do I have to hook it up to a machine to find the problem.
Old Mar 12, 2004 | 04:19 PM
cmoore99's Avatar
cmoore99
My '92 4.9L F150 (123000 miles) failed emissions in 01/04. The catalytic converter was the problem. The local Ford House was able to run a chemical rinse through the exhaust and get the catalytic converter cleaned out enough to pass for another year. It took two rinses. After introduceing the chemical they ran it on the highway to blow it out. Emission levels went way down. That was a good thing because a new cat is expensive.
Good Luck.
Old Mar 12, 2004 | 06:30 PM
acerockola77's Avatar
acerockola77
Yeah, I had a similar problem and it was the cat, I just put on 1 high flow cat for about $150 which isn't too bad, it passed the DEQ just fine.
Old Mar 13, 2004 | 08:21 AM
Hottemp's Avatar
Hottemp
Tryed the converter with no luck, i will try the o2 sensor next. I don't even have the check engine light on with these bad emissions.
Old Mar 13, 2004 | 08:26 PM
c96drumm's Avatar
c96drumm
Pull the codes. Even with no check engine light, there might be codes in there. I think the EGR is supposed to lower the nitrogen emissions, so you might look at that...
