2002 Leaking Gasket's?????
Old Mar 12, 2004 | 10:53 AM
travlnman's Avatar
travlnman
Exclamation 2002 Leaking Gasket's?????
I found what appears to be a leak at the front of my lower intake, driver's side.It's where the lower intake meets the head. It must not be and active leak, but it has leaked in the last 5k mi. I am not showing any loss of coolant in the resevoir, and I was changing plugs when I saw it. There was no evidence of burning antifreeze on the plugs, so I don't believe it's going into the cylinder, yet!!
Any other reports of newer 4.2's w/this problem???
I am bracing myself for the flood of replies
Old Mar 12, 2004 | 02:59 PM
true4.2's Avatar
true4.2
Mine has a VERY slow leak I think also. I have to put a couple of quarts of water in every few months. I almost think it's normal. ???
Old Mar 12, 2004 | 03:41 PM
BlueOvalFitter's Avatar
BlueOvalFitter
Normal? Thats the first indication of the lower intake gaskets going bad! Your next sign will be cylinders filling with coolant.....well,you know the rest! I would get it fixed ASAP!
Old Mar 16, 2004 | 06:44 PM
dustyjoe's Avatar
dustyjoe
hmmm...seem to be having a related problem myself on my 98. Its got 105k miles on it. What do you guys recommend as the best name gasket to use to fix it. Go with stock ford or felpro or what? Thanks
r.
Old Mar 17, 2004 | 07:29 PM
jbo2121's Avatar
jbo2121
i haven't put a drop of water in my 03 in six months....... doesn't sound normal to me.
Old Mar 18, 2004 | 08:20 AM
Busa01's Avatar
Busa01
yeah i agree. Sometimes when sitting in traffic for a bit, my engine bursts into flames and melts my tires down to the ground, but when I start driving, I pop my hood and let the wind blow the fire out. Of course then the hood is in my way so i crash into the car in front of me which sets off both my air bags and burns my face half to death. This happens about once a week..........I think it's pretty normal also though
Ah, sarcasm is a wonderful thing!!!!!
I don't think anything leaking is normal, perhaps you could at least have the torque on those bolts checked, at least.
Tom
Old Mar 18, 2004 | 09:30 AM
dustyjoe's Avatar
dustyjoe
....so How do you reload those airbags for the next fire. Mine only work once?
Old Mar 18, 2004 | 09:44 AM
Busa01's Avatar
Busa01
I have a very large custom PEZ Dispenser in the bed of my truck. It has a large Godzilla head on it. When I pull the head back (takes two people) a new airbag/steering wheel assembly pops out along with all the necessary hardware. The real problem lies in keeping the large plastic Godzilla head from fading in the Florida sun. This requires multiple coats of Meguires wax and frequent trips to the car wash. There's nothing worse than a large faded Godzilla PEZ Dispenser, let me tell you!!!
Uh, ok....acid flashback from college I think!!!
Old Mar 18, 2004 | 09:45 AM
Busa01's Avatar
Busa01
Man! I'm in rare form this morning!!!!!
Old Mar 18, 2004 | 09:53 AM
dustyjoe's Avatar
dustyjoe
hmmm.... that would work, only I'd need more than maguires wax to keep it from fading down here in S. Texas. Couple of years ago they had to shut down the interstate...3 weeks over 110 apparently melted it. (No BS).
Man you are in rare form
Old Mar 18, 2004 | 12:02 PM
travlnman's Avatar
travlnman
'Busa, you need to seek some counseling,but seriously, the "leak"has not leaked any fluid that I can tell. There is no loss of coolant in the resevoir, and no evidence of burning on the plugs, but I will fix it at the first opportunity. Right now I am chasing a p0401 code. I replaced the egr valve, butit still comes up. The solenoid is next to be replaced, maybe today.
'Busa I can help with that counseling if you need it. Appreciate all the comments though, sometimes we just need to lighten up and have fun.
Old Mar 18, 2004 | 12:08 PM
Busa01's Avatar
Busa01
Yeah i know, I was just busting on Joe's comment
He's used to it, or rather, me.
Old Mar 18, 2004 | 04:42 PM
BlueOvalFitter
Anyone seen my burning crickets?
Old Mar 19, 2004 | 08:47 AM
Busa01's Avatar
Busa01
Dude, you NEED to keep your darn burning crickets in the aquarium when your not using them. I found one in my freekin' soup last night. Normally I wouldn't mind, but they're too darn burnt and crunchy. I like my crickets a little more on the 'medium rare' side.
kyle.h
Jan 1, 2014 07:05 PM
North42g
Aug 20, 2011 07:22 PM
FordRun
Dec 22, 2010 04:23 PM
NTBTim
May 31, 2010 11:54 AM
scottfreeman
13
Sep 20, 2007 09:34 AM
