adjusting efi
Old Mar 12, 2004 | 10:14 AM
RbsFord's Avatar
RbsFord
adjusting efi
i have a 1990 f150 4x4 with a 302, and is running rich. i was wondering if there is any way to lean it out. i did'nt know if you can do this with timing, or if there is a sensor or relay some where that controls this. the tube that recirculate the exaust has been disconected this may be some of the problem i don't know. any help or info will be apperciated thanks
Old Mar 12, 2004 | 12:59 PM
EPNCSU2006's Avatar
EPNCSU2006
Pull the codes from the computer. It will usually point you in the right direction, and should not run lean on its own. One of the sensors is giving a reading that would cause the computer to inject more fuel. I would test fuel pressure, the fuel pressure regulator (make sure the diaphragm isn't punctured and fuel is being pulled into the vacuum line), and the oxygen sensor. I don't think EGR being disconnected would make it run rich. Pull the codes to start with for sure.
Old Mar 12, 2004 | 02:48 PM
Kemicalburns's Avatar
Kemicalburns
replace the o2 sensor and plug that egr tube back in. with out a custom chip your motor wont run right with out that tube connected
Old Mar 15, 2004 | 02:35 PM
RbsFord's Avatar
RbsFord
teh egr tube was disconnected when i bought the truck. it has been cut of with a tourch probally at a muffler shop. wher do i tie it back into the system at?
Old Mar 15, 2004 | 03:01 PM
Kemicalburns
the egr tube runs from the egr to the intake manifold right under the plenum. any wrecking yard should have one. or you can buy new but pay $$$ for it.
