Intakes....
Old Mar 11, 2004 | 04:26 PM
resqdawg3's Avatar
resqdawg3
Intakes....
So, can anyone out there in TV land recommend me a good intake? Which ones are you guys using, and how effective are they for you?
Any and all responses are more than appreciated!! TIA!
Ski
Old Mar 12, 2004 | 11:34 AM
6.0 on the Go's Avatar
6.0 on the Go
I posted the same question and the responces I got were mostly twards the afe intake system. do a search on the topic and you will find a post i did and the responces. I am going to be getting the afe soon it's your choice which one you choose
Old Mar 12, 2004 | 12:49 PM
Enomra's Avatar
Enomra
I have an AFE and like the way it fit into the original location and the increase in airflow is great, I also have a 4" exhaust and the edge attitude (wow). I recomend all of the above my friend with a Duramax and all the same equipment cannot keep up(not even close)
Old Mar 12, 2004 | 01:34 PM
resqdawg3's Avatar
resqdawg3
Sweeeet!! I have a friend that owns an Exhaust shop that is going to hook me up with a Turbo Back 4" for my truck. The chip is going to come later this year. Either that, or the Predator programmer.
Old Mar 12, 2004 | 02:25 PM
Enomra's Avatar
Enomra
Check into getting rid of the cat also as it realy restricts things and gets hotttttt!!!!!! the edge module is a great system if I were you I would call around and talk with shops that use or install both and ask them witch they prefer I did this and hands down they recomend the juice (I'm sure that the preditor is a great unit)but it will not monitor your temps and boost or detune at high egt's Good luck!!!
Old Mar 12, 2004 | 02:37 PM
resqdawg3's Avatar
resqdawg3
That's the plan....the Cat's are going in the trash. Totally catless and am going to run a Magnaflow muffler. :drool: Should be pretty badazz......!
I had thought about the Edge equipment, but with all the issues I've been reading about the tranny not liking the chip, I've been kinda leary since.
Old Mar 12, 2004 | 03:25 PM
Choctaw Bob's Avatar
Choctaw Bob
I have a K&N FIPK Generation II. The reasons.
1. It is the only one I could verify that an independent testing lab had tested and certified that it it is superior to the factory air cleaner in filtration.
2. It is as large as the stock air cleaner.
3. It includes a larger smooth inlet/mass air meter for improved air flow.
4. It is washable and reusable.
5. The stock ford air cleaner minder plugs into it.
6. It includes it's cold air box.
When I started the truck after installation, I could immediately tell the difference. I would guess about 20 HP
Old Mar 12, 2004 | 06:13 PM
psdwanabe's Avatar
psdwanabe
Can you share this info?
Old Mar 12, 2004 | 07:10 PM
Choctaw Bob
Here is one page. There are others available if you will search.
http://www.knfilters.com/facts.htm#RESULTS
Old Mar 12, 2004 | 08:52 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
I have the AirAide it is in my gallery with the cold air mods
Old Mar 13, 2004 | 12:50 AM
resqdawg3's Avatar
resqdawg3
I've been coming back to that Air Raid intake for a while now. I like the way it looks and the way it functions. I'm prolly going to go with it.
How are you liking yours, Tim? I'm diggin' that Ram Air mod that you did too! Was it pretty easy to accomplish? Did it require much cutting or anything?
Old Mar 13, 2004 | 06:35 AM
IB Tim's Avatar
IB Tim
Very little cutting I utilized some of the holes that were already there.
Old Mar 13, 2004 | 07:46 AM
psdwanabe's Avatar
psdwanabe
Thats not 6.0 filter specific. Ive yet to see independent testing on the 6.0 filter that shows better filtration or flow.
Old Mar 13, 2004 | 08:54 AM
SBV45's Avatar
SBV45
I haven't heard much out of Ford about the air filter. I don't know who actually makes it. I understand it was developed for use by the military in the early 90's Desert Storm. Since turbos are sensitive to "dusting" and in normal use this filter should go 50K or more miles, I'll stick with the current filter until I see some independent info that says something is better.
Now if I could mod this setup so that this filter gets a better flow of air.....
Old Mar 13, 2004 | 08:50 PM
tn mac's Avatar
tn mac
you might not want to take off the cats the dealers are telling alot of people it will void your warranty.
