Too high RPM idle -after rebuild
After removing the heads on a 1989 E-150 5.8 - van, and replacing the head gaskets- it's back together & I have the engine revvving.... at about 3000 RPM-I wonder if the fuel pressure regulator is bad, or if I may have made a mistake reinstalling the throttle position sensor- can anyone give an answer????
Failed fuel pressure regulator
To 'Franklin2'
The fuel pressure regulator developed a hole - and allowed fuel to run through the vacuum line and into the upper intake manifold. Under pressure from the fuel injection pump, and pulled through from intake manifold reverse pressure.
This caused the van - 1989 E-150 5.8 - to run out of gas several times, and to run very hot at idle.
After running out of gas the second time, a loud 'bang' occurred, and the head gaskets blew out.
After rebuild with new head gaskets, a vacuum leak was found in the most upper vacuum line, the one that runs into the unit above the EGR control unit.
With all of the electronic controls - Ford should build a failure warning mechanism, into the fuel pressure regulator, which will light up the warning light.
The failed Fuel pressure regulator nearly destroyed the engine through over-heating.
