engine ringing noise
Old Mar 11, 2004 | 10:53 AM
cajunbuck's Avatar
cajunbuck
Question engine ringing noise
Hi Everyone-
have a mystery that maybe someone could help me solve... when i start my 1994 f 150 auto. 302 V-8 and let it idle there is a noise in the engine that sounds like a distant telephone ringing that comes and goes.
friends have suggested it may have to do with the fuel pump, but i never noticed any other symptoms of fuel related problems until the other day. the truck starts up fine, but twice when i have put it into drive, the truck wants to die, but i give it some gas and it's fine. this happening got me thinking maybe the ringing is pump realted.
am i way off base or is this ringing/stalling a common symptom of a fuel problem?
thanks so much...
Old Mar 11, 2004 | 11:34 PM
c96drumm's Avatar
c96drumm
I had a phone on my 89 302, turned out to be the spark plug heat shield vibrating against the exhaust manifold.
As for the idle, check the IAC, see if it's dirty/sticking or inop. Always a good idea to pull the codes, too.
Old Mar 12, 2004 | 09:54 AM
cajunbuck's Avatar
cajunbuck
thanks for the help.
I want to pull the codes by this weekend to see what else I can find, but this ringing seems to happen when the compressor turns off after the engine has been idiling for a while.
when the compressor kicks on, the ringing seems to stop, but when it stops, the ringing happens. its not a constant ring, but just like a phone... rings then stops and then again...
any other suggestions???
Old Mar 13, 2004 | 05:37 PM
fordnut1985's Avatar
fordnut1985
cajunbuck, it might not be compressor related it could just be the difference in idle speeds when the compressor is off compared to when it is running, just a thought. i had a 92 f-150 with a 302 and it had a funny ring that was very faint never had any problems with it so i never tried to find out what it was!
good luck
Old Mar 13, 2004 | 08:42 PM
Slade901's Avatar
Slade901
Can you make a recording on that sound that sounds like a phone ringing on your engine? I would like to hear it and learn something from this issue.
Old Mar 13, 2004 | 09:00 PM
WALJON's Avatar
WALJON
I had this ringing problem on an older truck It was the fly wheel had a crack!
