combustion camber
Old Mar 11, 2004 | 09:12 AM
weldingfreak's Avatar
weldingfreak
combustion camber
Any boby know what heads i would need to raise my compression on my truck stock heads that are readly avalable
Thanks
Old Mar 11, 2004 | 08:59 PM
neverenough's Avatar
neverenough
C8VE-D0VE heads, make sure you get the correct length push rods for the rockers. Should put it in the 9.4-7 to 1 CR.
The heads are basically the same ones you already have with smaller cc chambers, so, milling up to .040 off the ones you have is another option. .040 is the total the head can be milled. If they have already been milled, that has to be subtracted from the .040. If you mill the heads don't forget to mill the intake too.
69issofine
Dec 6, 2014 09:33 PM
ford4x4956
Mar 9, 2010 09:55 AM
PsD007.3
29
Nov 4, 2009 10:04 PM
erikl85
27
Dec 2, 2002 04:19 PM
jdbanks
May 14, 2002 03:28 PM
