Guys, please help...I'm going nuts. Please.
Old Mar 13, 2004 | 06:22 PM
jwtaylor's Avatar
jwtaylor
I say take a look at what fordpilot mentioned, makes sense, if the sound came from that area.
How did the motor run when you did get it to fire?
My distributor if the timing is off as in 0-2 BTDC would make a grinding noise, again I am not sure how loud your sounds is, but mine if severely out of time, would make such a noise. Should you figure it out you have to post the results, I am very interested in finding out what is causing your problems.
Good luck
Old Mar 14, 2004 | 12:15 AM
aharrell's Avatar
aharrell
guys....I forgot to tell you that my buddy got under the truck (yikes!!) and watched the starter engage, then disengage properly. That is the first thing we thought of, but it's working just fine, every time. But we know for a fact that it disengaged, and the noise still happened.
The motor fires off every single time. If I didn't shut it off it would keep running, but I can't stand the noise for more than a second.
The noise is pretty loud. I might try to record it and post it somewhere.
We are turning the motor until the number 1 piston gets to TDC. And the firing order I'm using starts with the 1-5 for the standard 302, and not the H.O. firing order. After it gets to TDC, we put the distributor down in the hole and get the rotor lined up with the number one piston.
Old Mar 14, 2004 | 12:18 AM
aharrell's Avatar
aharrell
Old Mar 14, 2004 | 07:02 AM
jwtaylor's Avatar
jwtaylor
Well, get a few friends, everyone stick their nose in the engine bay, have someone fires the engine for a couple of seconds, and listen for the noise. Otherwise, unless you can find the answer, your gonna have to tear that engine apart and inspect it.
The flexplate isn't hitting/rubbing anything, don't know why or how it would but you never know?
Are you using a efi timing cover electronic fuel pump or are you using a timing cover with the fuel pump opening~ mechanical pump? If mechanical, could your fuel pump arm be rubbing the timing cover? I am trying to think of everything I can, I would say you already have thought all this over, but figured I would throw it out there. Good luck once again
Old Mar 14, 2004 | 08:01 AM
fordpilot's Avatar
fordpilot
No 1 piston on TDC has got many people..it
has to be on the compression stroke..the
valves will be closed. TDC on exhaust
stroke is timing off 180 degrees. I have done
that error and recall mondo bad noises.
Crank rotates 720 for each 360 camshaft on
4 stroke. Double check me figures as it
is kind of a mind twister got to draw it
out for me.
Keep posting..very interesting prob.
Old Mar 14, 2004 | 11:20 AM
aharrell's Avatar
aharrell
JW: I'm using the timing cover that came off of the functioning (but leaking) motor that I just pulled out of the truck. When I pulled the cover off I looked for any indications of that arm rubbing, but there was nothing. I've pondered the flexplate, but again, no signs.
Fordpilot: I'll recheck the timing.
I'm going to make a recording if I can and convert it to a small mp3.
Old Mar 14, 2004 | 08:23 PM
aharrell's Avatar
aharrell
problem solved
Well guys, after this I doubt I will ever post here again because I will be booed off of the stage. It was an air leak at the carbureator adapter. The back of the carb was sticking over the metal plate by about a 1/4th inch. I cannot believe it.
I have never in my life heard a sound that sounded so mechanical and scrubbing, and it turned out to be a freggin' air leak. After fixing the leak it cranked right up, and after adjusting the timing it's running great.
It sure is sweet having an AOD in a '76 model truck.
I'm sorry I wasted everyone's time, but I've learned a good lesson. Air leaks can do some WEIRD things.
I think JWtaylor hit the nail on the head pretty early on but I kept disagreeing. THANKS!
Old Mar 14, 2004 | 08:38 PM
fordpilot's Avatar
fordpilot
Man I am glad you solved your problem. With that
leak working against the venturi you
probably had a mini pipe organ. Keep truckin!
Old Mar 15, 2004 | 12:16 PM
jwtaylor's Avatar
jwtaylor
Glad you have it running. Good luck in the future
Old Mar 15, 2004 | 09:38 PM
aharrell's Avatar
aharrell
biggest relief I've had in a while. I still can't believe the sound it was making.
BRay09
27
Sep 23, 2011 08:22 AM
madfrdman
May 22, 2011 08:58 PM
allen o
Dec 31, 2008 08:24 AM
masterkiller214
1978 - 1996 Big Bronco
Jun 23, 2002 12:01 AM
masterkiller214
Jun 19, 2002 10:50 AM
