Sponsored by: Real Truck
vin help ?'s
Old Mar 10, 2004 | 08:30 PM
DVR's Avatar
DVR
vin help ?'s
i have found what i feel is a great deal on a 2004 f250 king ranch crew 4x4. the dealer is unsure of the axle ratio and a few other goodies. the truck was purchased and then traded for a excursion a month later so the window sticker is missing.
can anyone direct me to a site where the vin can be put in and the opitions then listed?? any other suggestions?
thanks in advance.
Old Mar 10, 2004 | 08:44 PM
Yeti's Avatar
Yeti
You might find some of the info your looking for at the top of this forum, under decipher your vin#
Old Mar 10, 2004 | 09:44 PM
DVR's Avatar
DVR
i guess that would be a good place to look. sorry i'm new here and did not see it. thanks for the heads up.
NoMo's Avatar
NoMo
About the only option you can find with the VIN is the engine.
The dealer should be able to run the VIN through the Ford database and print a new window sticker. At the very least, they should be able to look up the options for you. If they won't (or can't) then I'd be a little suspicious.
