351? locked up
Old Mar 26, 2004 | 01:37 AM
Torque1st's Avatar
Torque1st
Posting Legend
Pull that motor out of there and rip it apart. Clean up all of the parts and label them. You can learn a lot.
You can post pics in your gallery here but they can't be linked to from outside the site.
Old Mar 30, 2004 | 11:58 PM
paragod's Avatar
paragod
Thanks for the advice. I've done several rebuilds, they were just all on chebbies. I learned from the 350 4bbl and 350 auto trans. in school. I just finished the heads, and found 3 stuck valves in the process. You wouldn't believe the amount of crud I dug out. I will throw those pics in my profile, and keep updating as I go. I do have one question: I'm trying to decide if I should have the heads shaved while they're out. It's a 351m with a stock setup.
Old Mar 31, 2004 | 03:57 AM
scroob's Avatar
scroob
Whether you should have the heads shaved depends on whether you use dished or flat top pistons.
I wouldn't build it as a 351 when all you need is a 400 kit (w/crank and pistons) to make it a 400. 49 free cubic inches.
Old Mar 31, 2004 | 06:52 AM
danlee's Avatar
danlee
Use a 400 crank, badger flattop pistons, and take 0.010 off the head to make it 9:1 CR. Do some porting work add headers and a cam that makes power where you want it.
Old Mar 31, 2004 | 08:59 PM
paragod's Avatar
paragod
sounds like a pretty good idea. I may ending up rebuilding it as is until I can afford to the more extensive mods. I found out that shaving the heads is inexpensive, but the 400 kit runs about five to six hundred for the basics.
Old Mar 31, 2004 | 09:33 PM
grclark351's Avatar
grclark351
it's not really any additional expense if your crank needs attention. the crank and pistons are a standard replacement item by definition in a rebuild, an overhaul is a different story. shop around and the cost might come down a bit too.
Old Apr 1, 2004 | 01:23 AM
Matts72's Avatar
Matts72
sounds like i need to pay more attention to that 400 in the junkyard. I wasn't aware that it would be salvageable. Although there is no guarantee that the crank is still in one piece, something is holding in in place, I can't turn the motor to remove the flywheel bolts to get the motor out.
Old Apr 1, 2004 | 01:29 AM
paragod's Avatar
paragod
drop the oil pan and have a look. I'm learning a lot about what a little water will do to the inside of an engine. I found an OE rebuild kit at the local auto store for about 200, so I'm sticking with it for the moment. They are also doing the machine work for about another 150. (valve job, shave the heads, crank turned, bearings pressed, bores refinished.)
thomasstemmle
Aug 17, 2016 10:30 AM
Aaron-71
27
Mar 21, 2016 10:53 AM
GaryKip
Jan 19, 2016 05:19 AM
AbandonedBronco
13
Feb 19, 2015 09:21 AM
gblakeney
Nov 6, 2001 09:45 AM
