Sponsored by: Real Truck
Oil Puddle Next To Distributor
Old Apr 6, 2001 | 08:42 PM
a2zbuilder's Avatar
a2zbuilder
I own a 1993 Super Duty with a 460 engine. In front of the distributor shaft and on top of the water pump is a puddle of oil I have to clean up every week. Does anyone have any idea of where this oil originates from? Could it be coming from the distributor shaft?
Old Apr 10, 2001 | 02:12 PM
magnus's Avatar
magnus
Your intake gasket is probably leaking.
If you're not mechanically challenged, buy a gasket kit and install it, should only take a Saturday afternoon.
If you didn't build it, its not really yours.
Old Apr 11, 2001 | 09:15 PM
a2zbuilder's Avatar
a2zbuilder
Magnus:
Is there any test to prove where the leak is? Also, another question is will this gasket breach effect engine performance?
Thanks,
Thomas
Old Apr 11, 2001 | 09:43 PM
magnus's Avatar
magnus
cleaning the area and checking after a few minutes of engine operation to see where the oil is coming from, is probably your best bet. as far as performance, if its an oil leak it won't affect performance any.
Old Apr 12, 2001 | 09:44 PM
a2zbuilder's Avatar
a2zbuilder
Magnus:
You inspired me to undertake the repair. I'll let you know how it goes.
Thank you!
Old Apr 15, 2001 | 12:01 AM
heyvern's Avatar
heyvern
Old Apr 17, 2001 | 10:01 PM
magnus's Avatar
magnus
good luck, lemme know
