Sponsored by: Real Truck
finicky gas tank
Old Sep 4, 2000 | 07:15 PM
Mulepick's Avatar
Mulepick
finicky gas tank
I find that when I fill the tank normally (shove in the nozzle, lock in on high, daydream till done, top it off) my tank will still hold almost 5 gallons more. You have to baby it in by trickling it in until it's almost ready to overflow. Anyone else have this problem or, better yet, a fix?
Thanks,
Bob
Mulepick(No Email Addresses In Posts!)
2000 F-250SD X-cab SB 4x4 auto 4.10LS
5.4L off-road and camper packs
Old Sep 4, 2000 | 09:44 PM
Roger_B's Avatar
Roger_B
finicky gas tank
I've never gone through the exercise to 'completely' fill the tank. I usually fill up at the same station/same pump to get consistant fillups so I can check mpg..
I think if the truck is facing 'downhill' a bit, it will fill up more than if its level or uphill..
I also have a 4x2, which is slightly nose-down anyway compared to a 4x4 which might make a difference.
Old Apr 15, 2001 | 12:01 AM
heyvern's Avatar
heyvern
finicky gas tank
My '99 does the same thing. Just remember, that is extra gas. My tank is a 29 gal, but I have put as much as 31.9 gals in it.
Old Apr 16, 2001 | 07:51 AM
odinmurphy's Avatar
odinmurphy
finicky gas tank
My 2000 CC does the exact same thing. If you hear of a fix for this problem, I would be interested in knowing about it.
thanks
Murph
Old Apr 17, 2001 | 11:53 PM
red99sdv10's Avatar
red99sdv10
finicky gas tank
Old Apr 18, 2001 | 12:15 AM
red99sdv10's Avatar
red99sdv10
finicky gas tank
problem even worse with a diesel first 20 gals real quick especially with a big truck hose last 3 gals takes forever
