Sponsored by: Real Truck
Check Engine Light
Old Jan 8, 2001 | 08:01 PM
donmarci's Avatar
donmarci
Check Engine Light
99 Ford, F250 Super Duty, v10, 4x4, 40,500 miles.
Have experienced at least 8 or 10 service engine soon lights and each code that was detected stated EGR flow restrictions. Replaced EGR and performance plus gas mileage improved. However,after a recent trip to Colorado, the light is back on again with same code. Only modification to vehicle has been the installation of a K&N filter system.
Prior to the replacement of the first EGR valve, after light came on, gas mileage dropped drasticaly. However, this time no drop in gas mileage but performance seems on the down side when climbing.
Any recommendations to solve problem.
Old Feb 7, 2001 | 04:11 PM
gragan's Avatar
gragan
Check Engine Light
how did you determine that the service engine soon (s.e.s.) lite
was due to EGR? I have a 99 f250 SD v10 auto and i have no
idea how to go about figuring out why my s.e.s. lite is on .
gregg
Old Feb 8, 2001 | 08:31 PM
donmarci's Avatar
donmarci
Check Engine Light
See your friendly mechanic or an individual that owns a Snap On computer and this device will give you the fault code and reason.
Old Mar 13, 2001 | 11:02 PM
a2zbuilder's Avatar
a2zbuilder
Check Engine Light
HELP
My 1993 Ford 450 Super Duty with a 460 engine was found to need EGR valve. I purchased the subject valve through the Auto Zone (retail auto parts) and in reading the replacement instruction, I learned that each EGR valve is calibrated for the specific engine application. The OEM number on the original valve must always be referenced to determine the replacement valve used. Can anyone help me identify the OEM number for this truck? I am seeking this information prior to removing the original valve for fear that the valve I purchased may not match. The replacement valve's packaging identify's the valve as a EGR231; The replacement valve is also stamped with the following number 39199344.
Thomas
Old Apr 18, 2001 | 09:06 PM
spridget's Avatar
spridget
Check Engine Light
I'm not sure if any of this will help, but I'll toss some ideas out there anyway. This is based on having a check engine light on my '97 F350. The code was EGR flow problem (can't remember exact wording). It happened immediately after changing plugs and wires, so I was sure I caused it. Problem was I just couldn't figure out what I had done. Anyway, after talking to mechanics and surfing the web, EGR problems aren't necessarily the valve. There could be blockage within the head caused by carbon and such. There is a way to check the EGR valve with a vacuum unit. Another source of EGR problems is the solenoid, and possibly a bad/cracked/disconnected vacuum line somewhere. The only way to be sure of this part is to trace each wire and hose. One is probably green-from the valve, and one is probably pink-from the solenoid if I remember correctly. It turned out the hose was bad on one of the main vacuum containers on my truck. Again, there are ways to check the EGR system but it isn't exactly trivial. I advise tracing all the wires and hoses first. Good luck!
Old Apr 19, 2001 | 06:24 PM
hightech's Avatar
hightech
Check Engine Light
Hello< I am a master certified tech, in reference to your EGR problem:
Most problems occur with this system when the port on the intake side of the valve gets plugged with carbon. Remove the valve and check the port, if it has carbon in it you will need to clean it out. The carbon is usually gummy in nature. Removing it on the late models is done by removing the upper intake, as for the older units, it depends on the engine.
Make sure you don't let any fall into the intake, I use a shopvac for safety.
The reason this sets a Check Engine Light is because the computer is monitoring EGR flow rates. It can happen to any vehicle and is usually caused by poor fuel quality and alot of city driving. It never hurts to take them out and "Blow the dust out".
Hope this helps, Tim
2001 F250SD 4X4 V10
Old Apr 19, 2001 | 06:27 PM
hightech's Avatar
hightech
Check Engine Light
rcknrbn
Sep 9, 2008 08:47 AM
rangeron
1983 - 2012 Ranger & B-Series
27
Jul 27, 2005 09:24 AM
Expo-64
Jun 14, 2004 09:49 AM
jaman
1997 - 2003 F150
May 20, 2004 04:55 PM
Stacey
Mar 5, 2000 03:26 PM
