302 Tps
Old Mar 10, 2004 | 10:37 AM
Talyn's Avatar
Talyn
302 Tps
Is it that sensory on the side of the throttle body?
A picture will help.
i only have pictuer for 351.
Old Mar 10, 2004 | 12:28 PM
truckfanactic's Avatar
truckfanactic
It should be on the bottom side of the throttle body. Hope this helps!!
Old Mar 10, 2004 | 12:30 PM
EPNCSU2006's Avatar
EPNCSU2006
351 and 302 throttle bodies look exactly the same.
Old Mar 11, 2004 | 10:49 AM
sicbpguy's Avatar
sicbpguy
The TPS will be on the opposite side of the Throttle Body as the linkages. The "axle" that the plates rotate on hooks into the TPS.
Old Mar 11, 2004 | 02:17 PM
Talyn's Avatar
Talyn
hopefully i can find it! needs to be replaced badly.
Old Mar 11, 2004 | 02:24 PM
frederic's Avatar
frederic
You can't miss it. Its the only flimsy plastic thing on or near the throttle body with wires hanging off.
Just be careful with the connector, you're going to need to plug that into the new sensor. I've ruined a few in my day, and I can tell you that duct tape only works so long
Old Mar 11, 2004 | 03:19 PM
Talyn's Avatar
Talyn
yea, i hate car electronic clips. They are so poorly designed on any vehicle.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
