1978 - 1996 Big Bronco
89 Bronco 5.0 EFI stalling
Old Mar 9, 2004 | 03:57 PM
RichVollberg's Avatar
RichVollberg
Hey all, I have a 89 Bronco with the 5.0 EFI system. Ive done a complete tune up from ign module to coil, and wires and plugs, cap and rotor. still getting a low idle of 550 rpms.
I also get a surge every now and then. If its warmed up and I drive with the ac on it will stall every time, when I come to a stop it also does it with the ac off just not as frequent. I did a code test , no light on mind you and it did flash a code 67. havent been able to find that code any where. engine seems a little low on power to me but ill tell ya the last ford I owned was back in 79 and it was a 75 gran torino. This ecm system is driving me nuts. I have to admit Ive been a chevy owner most of my life and fords just baffle me.
Rich Vollberg
Old Mar 10, 2004 | 10:33 AM
sactrack's Avatar
sactrack
if you want to increase your idle, you need to use a small Allen wrench (not sure of the exact size) and mess with the screw on your throttle body that sets the idle.
Old Mar 10, 2004 | 12:32 PM
RichVollberg
From what ive been told that screw should not be messed with its factory set and the idle should remain constant unless a part is worn out.
Old Mar 10, 2004 | 12:37 PM
sactrack's Avatar
sactrack
he he he... well.. that's probably true. On the other hand, my screw had wiggled its way loose to the point that when I had my AC blowing on HI and would come to a stop, my truck would stall. I took it over to my buddies house (his dad is the shop foreman at a chevy dealership in town.... and he messed with the screw a bit.... haven't had a problem since)... so... just a suggestion that may or may not help, but worked for me
Old Mar 10, 2004 | 12:40 PM
RichVollberg
Ya i treid it just in case but i couldnt get any change and it was almost all the way in anyhow. Thanks for the info though.
