1978 - 1996 Big Bronco
manual hub conversion 93 bronco
Old Mar 9, 2004 | 11:36 AM
mudbath's Avatar
mudbath
this is my first time on this site so bear with me. my cousin just bought a 93 bronco. we went to do his brakes and couldn't get the hubs off.[ha,ha]learned that we needed the socket for the lock-nuts so we got that.now my question is, is there anything else we need? he also bought man. hubs after i put man.hubs on my 92 ranger. i needed a conversion kit so my other question is will he? any input you fellow ford enthusiast have will be GREATLY APPRECIATED. thanks in advace
Old Mar 9, 2004 | 02:51 PM
bigric's Avatar
bigric
You won't need a conversion kit for a '93.
http://www.broncodata.com/tech/tshubconv.htm
Old Mar 9, 2004 | 02:54 PM
Broncobirdy's Avatar
Broncobirdy
Ric is right. I just did mine last week. No problem, no aditional kit needed. I did all the brake components and ended up doing the wheel bearings also.
Old Mar 9, 2004 | 09:14 PM
mudbath's Avatar
mudbath
is there any parts off the old ones besides the lock nuts or maybe a web site with a diagram?
Old Mar 10, 2004 | 01:47 AM
bigric's Avatar
bigric
I'm not sure what you're asking about old parts. But here's Steve83's gallery:
http://www.superford.org/registry/v...ail.php?id=2742
Check out "Brakes and Hubs"
Old Mar 10, 2004 | 10:39 AM
mudbath's Avatar
mudbath
I got it figured out now. It took awhile to get the hubs and rotors seperated but everthing is good to go now. The manual lock-outs slide right in place. The only problem was we found out that his r.axle was broke right on the u-joint? Guess the last owner never changed them cause the one on the L.axle looks like hell too. So today we do the u-joints and then his bronco should be ready. That thing can really go through the SH--. I might have to get one to go along with my 92 ranger [my mud tub].THANKS A TON FOR THE INPUT/HELP. I don't know if it's my settings or a wrong address but I wasn't able to see Steve's gallery. I'd still like a look just to make sure we got it right before the " road test". Thanks again
Old Mar 10, 2004 | 01:19 PM
bigric's Avatar
bigric
Glad you got it worked out. It's not your settings, BTW; Superford seems to be having problems.
fordf350man
Nov 2, 2015 12:20 PM
Primersthebestest
May 18, 2015 11:46 PM
seadog1
Nov 11, 2014 02:01 PM
mudslinging79
May 6, 2014 09:33 PM
deepbass
Oct 12, 2012 09:03 PM
