Best Oil Filter?
Just looking at the Wix / Napa filter while filling it with oil realized that it is a much better quality filter - Screw Fram!
One contributor mentioned the filter for the F-150 from Canton Racing Products. The filter is advertised to work down to 8 microns, about half of what the better "Throw-away" filters advertise. It's very expensive, and uses replacement elements, good for 10,000 "street" miles, fewer miles for racing. It's a "billet" aluminum spin on, re-useable, of course, with the replacement elements, adv. good for the "life" of the truck. I took the plunge because of the 8 micron filtering. It arrived, looks well made. I will have to order replacement gaskets and O-rings, when the originals wear out. Is it worth the expense to get the 8 micron filtering?
Are 8 micron filters is worth it. In hydraulic systems yes in our engines (or any production engine) problably not. Here's why... Most good filters will filter down to 40 microns or below. A micron is on .00003937 of an inch. 40 micron is .0015748 of an inch much smaller than tolerances inside engines. Granted, can some benefit be gained by filtering down to 8 microns maybe.
3 dollars...5 dollars..who cares? The thing is less expensiv then damn air filters are, that's teh good thing. My grandpa was a trucker for years, and him and his buddies use Wix exclusively. It's two dollars more...and if truckers use it then I don't see a reason not to. Hell...the place down the street that uses fully certified oil by the barrel and does 12 dollar oil changes uses wix filters...they don't even make money off oil changes, I swear. Course...they just want you to go there for tires and stuff.
