Sponsored by: Real Truck
How common is this configuration?
Old May 26, 2001 | 10:41 PM
stb's Avatar
stb
F-250SD
SuperCab
Short box
4x2
V-10
3.73 axle ratio
Is this common, or do most people go with the 4x4 for the short box?
Thanks,
Old May 27, 2001 | 12:35 AM
Oaf's Avatar
Oaf
I just bought the same configuation except I have a 4x4. My buddy also just bought the same configuation with the 4x4 as well.
Old May 27, 2001 | 09:09 AM
stb's Avatar
stb
Ok, but you have 4x4. The config I'm mentionning is 4x2.
Old May 27, 2001 | 12:20 PM
V10man's Avatar
V10man
I've seen a few around. What's it matter really. Ford will build it so if ya want one order it!
Old May 27, 2001 | 03:28 PM
stb's Avatar
stb
The issue is mostly a matter of resale value.
Don't want to be stuck with something I can't sell down the road.
Cheers,
Old May 30, 2001 | 09:21 AM
Cabover's Avatar
Cabover
It is very comon.
I have the same configuration with the addition of limited slip differential.
It works great towing my 35 foot Titanium 5th wheel
Old May 31, 2001 | 06:42 AM
mjs's Avatar
mjs
>of resale value.
>the road.
>Cheers,
Resale on a 4x2 really depends on your location. here in MN, resale on a 4x2 is poor. I would guess that 90% of trucks sold here are 4x4. Probably a different story in southeren states.
MJS
Old May 31, 2001 | 01:10 PM
rob_n_houston's Avatar
rob_n_houston
I don't think this is a common as a 4x4 with a psd. I had a link the other day that had Fords recommendations on what a dealer should stock. 4x4 psd's were over 50 percent if I recall. Short boxes are recommended over long beds. If I find the link I'll post it. As someone mentioned the recommendation I saw could be a regional one.
Rob
1999 F-250 SD CC V-10 LWB SRW 4X4 Lariat Red clear coat 33x12.5 on 16.5x10.5" wheels K&N
Old May 31, 2001 | 08:19 PM
wilsonv10's Avatar
wilsonv10
I have a 99 F-250SD, Lariat, Crew-Cab, 2wd, v10. Not sure about rear axel. I use it to pull a 24 foot enclosed car trailer, about 7000 pounds when loaded. I see this combination used often for work trucks here in Charlotte NC although most of the private owner have 4x4's.
Old Jun 1, 2001 | 07:35 AM
robncandy's Avatar
robncandy
