best heads?
Old Mar 8, 2004 | 08:31 PM
TUFFY's Avatar
TUFFY
best heads?
I'm sure this has been asked and answered here a lot before so please bear with me. Will cleveland heads work on a 80 351m the heads i'm looking at are off an 70 model if they will will there be much of an improvement in torque or horse power or should i just redo the 351m heads i'm rebuilding the 351m right now will be 30 over rv cam ,aluminum intake, ect.
Thanks Dave
Old Mar 9, 2004 | 10:07 AM
Bill_Beyer's Avatar
Bill_Beyer
If they're 2V heads then you're looking at potentially a little improvement based on the exhaust port configuration of the earlier Cleveland heads.
Now it they're 4V then it's a whole different ballgame.
Both 2V and 4V are direct bolt ons. No modification to the block is necessary.
Old Mar 9, 2004 | 07:32 PM
Ecuri's Avatar
Ecuri
A 400 crank and some cheap pistons would do more for you vs the heads, IMO. You have investigated this, right?
Old Mar 9, 2004 | 08:20 PM
67 F250's Avatar
67 F250
I think the early heads are thinner. I have had water seepage from the head gasket under 1971 351C and 400 heads on my 351C. Also two have cracked. Block has been decked and heads have been surfaced. I now have a 1978 351M head on one side and no water seepage on that side. That head does have the large lump around the exhaust guide but I don't know how much it effects the flow.
Wolfe26
Sep 24, 2016 05:28 PM
Nolan8976
Aug 7, 2016 11:27 AM
steve33444
19
Dec 12, 2014 08:33 PM
mejonz
Jun 1, 2014 12:58 AM
josh nowak
Apr 9, 2007 07:23 AM
