stalling engine
Old Mar 8, 2004 | 08:11 PM
hog wild's Avatar
hog wild
stalling engine
i bought a used 2001 f-250 4x4 7.3 with 20,000 miles about
3 times when applying the brake the truck starts to jerk and
then the engine dies i will start right back up just fine. i took
back to dealer to have the codes cheked but were none.
any ideas?
Old Mar 8, 2004 | 08:13 PM
87MarkVIILSC's Avatar
87MarkVIILSC
maybe theres a vacuum leak somewhere.sounds like your brakes are takin all the vacuum away from the engine
Old Mar 8, 2004 | 08:17 PM
hog wild's Avatar
hog wild
can low oil level cause this problem i heard it could somehow?
Old Mar 8, 2004 | 10:13 PM
whalerron's Avatar
whalerron
Vacuum?!? This is a diesel....
Old Mar 9, 2004 | 07:17 AM
powerstroker250's Avatar
powerstroker250
No vacuum for a diesel. Maybe the torque convertor is staying locked up assuming it is an automatic.
Old Mar 9, 2004 | 02:20 PM
JMorton's Avatar
JMorton
If the torque convertor is staying locked, It'll feel like a standard transmission does when you come to a stop and forget to push the clutch pedal in. It usually sets a code if this happens but not always.
