question about pinging
Old Mar 8, 2004 | 03:30 PM
bobzilla67's Avatar
bobzilla67
Unhappy question about pinging
I have a 93 ford ranger that has 280,000 miles. It runs good most of the time but when the engine temp comes up and i give it half or more throttle it begins to ping and lose power.
The only thing that i have tried so far is to use various types of engine flush and restorer.
Any ideas?
any and all help is appriciated
93 ford ranger extended cab
4.0 v6
6 inch lift
33 inch tires
Old Mar 8, 2004 | 04:04 PM
AG4.0's Avatar
AG4.0
It probably needs to be decarboned.
Decarbon the 4.0
Also, if you have other problems, check the sticky at the top of the Ranger Forum titled technical information. There is a lot of different threads linked in that sticky that can help out. That's where this link came from.
Old Mar 8, 2004 | 10:44 PM
hreed's Avatar
hreed
Carbon certainly is a likely candidate, but there are several other things that come to mind. First is the timing. Usually, when an engine pings, it is because the timing is off. Carbon deposits on the piston retain heat, and will ignite the fuel before the piston reaches the optimum. It is kind of like a little glow plug. What kind of driving do you do? Home to work to store to home, or do you drive it for an hour on the freeway? Short hops will carbon up; long trips will eliminate the problem. Or it could be something as simple as a bad batch of gas. Keep us posted.
Old Mar 9, 2004 | 04:14 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
The three most common reasons for ping in the 4.0L are:
1) Dirty MAF sensor
2) Loose intake bolts
3) Carbon buildup
Timing on this motor cannot be be adjusted and is managed electronically. There is a jumper which, if removed, backs the timing off by 2 degrees. Leave it alone as removing the jumper is masking the real problem and will cost you power and mileage. You will also note that the TSB for #3 advises not to use midgrade or superduper unleaded as this can aggravate the problem.
Old Mar 9, 2004 | 03:26 PM
bobzilla67's Avatar
bobzilla67
thanks for the tips i will try all of them. I do a lot of driving around town and lots of spirited off road jaunts.
Old Mar 9, 2004 | 03:36 PM
js9's Avatar
js9
> It probably needs to be decarboned <Decarbon the 4.0>
You can blow out most of the carbon without the special cleaners. Just slowly pour about 8 oz of plain water down the intake while keeping the revs up.
