ID a Dump Truck
Old Mar 8, 2004 | 03:03 PM
Butter's Avatar
Butter
ID a Dump Truck
A friend of mine has traded for an old farm Dump Truck. Is there a place to get the VIN# of that truck other than the left door. Both doors have appearantly been replaced as the color is different than the cab.
The engine looks similar to the 352-390 engine family class. The engine sports a generator and the distributor vacuum advance is factory hard lined to the carburator. Carb has an oil based breather.
It has a 5 speed manual transmission with reverse all the way to the right and up and granny first all the way to the right and down. It is a single axle with an electric spit shifter.
Upon first glance it appears to be an early 1960's model. Can someone point me to some links to pics of trucks around those years? I remember driving some like it when I was a kid working at a feed mill but I don't know the exact year.
TIA
Old Mar 8, 2004 | 03:16 PM
banjopicker66's Avatar
banjopicker66
Look in the following places:
1. In the glove box;
2. Down alongside the radiator supporting rail, most likely on the passenger side;
3. On top of the frame rail on the passenger side. You will most likely need a wirebrush to scrape dirt and rust off. If is is as far back as to be under the cab, you will need a small mirror.
Old Mar 8, 2004 | 06:35 PM
merkstang's Avatar
merkstang
check my garllery Ive got a 65 F350
Old Mar 9, 2004 | 08:29 AM
Butter's Avatar
Butter
merkstang,
It looks a lot like your 65 but it has the parking lights in the grill beside the headlights instead of just above the headlights. It also has parking lights out on the fenders too.
One other distinguishing feature is the battery is located in the passenger side floorboard.
Professor M
1947 and Older Ford Trucks
25
May 22, 2017 08:40 PM
deck60
Vehicles for Sale
May 11, 2017 08:51 PM
46Whizzer
Nov 7, 2016 02:34 PM
steeltoes
Mar 30, 2016 11:11 PM
MarkMoore
Jul 5, 2010 11:47 AM
