Grind into first, if not stopped
Old Mar 8, 2004 | 09:39 AM
Bradley Rieke's Avatar
Bradley Rieke
I have a 2000 f-250 with the turbo diesel, and a six speed manual transmission with 99,000 on it. I just got a new hydraulic clutch, and since then I have trouble getting it into first. I experienced this immediately after getting my truck back from the transmission shop. I informed the mechanic of the change, but he did not believe this to be related to the newly installed clutch. The truck will shift into low or reserve when I am stopped. I have always been able to at least put the stick in the slot with the clutch depressed, and slowing to a stop. Now, I have to be under 2-3 miles an hour in order to just get the stick into the slot without grinding. I would think this is a function of the clutch?
Old Mar 8, 2004 | 10:42 AM
78fordman's Avatar
78fordman
You need to probably adjust your clutch in a little bit more.
Old Mar 8, 2004 | 12:09 PM
Boss_358's Avatar
Boss_358
I don't think there is anything really adjustable when you have a hydraulic clutch. But I am also not very familiar with the clutch set-ups on those trucks.
Old Mar 8, 2004 | 07:16 PM
78fordman's Avatar
78fordman
Could be a throw out bearing or something like that, but i assume they changed that when they changed the clutch.
Old Mar 8, 2004 | 10:16 PM
FordPerf300's Avatar
FordPerf300
The clutch master and slave need to be bled more, the clutch is probably not releasing all the way.
Old Mar 11, 2004 | 11:06 AM
Bradley Rieke
I'll try the clutch bleeding. The hydraulic clutch doesn't really adjust, but it does seem like with the clutch depressed I should be able to slip the stick into gear. Thanks.
