Stupid Plugs!!
Old Mar 7, 2004 | 08:14 PM
MisterCMK's Avatar
MisterCMK
Stupid Plugs!!
Well, I dug into the plugs today. I got the entire passenger side done, and then took a crack at the drivers side. I couldn't get the bolt for the COP off of the rearmost plug on the drivers side. I couldn't even get the socket onto the bolt because of the fuel rail. How did you guys get that COP off. The rest of them don't look to bad. I left the old plugs in, and am gonna finish it up tomorrow after reading up on how to get them off the drivers side. Thanks guys
Old Mar 8, 2004 | 12:15 AM
hceptj's Avatar
hceptj
Try this link...http://www.mattstruck.com/sparkplugs/sparkplugs.html
Old Mar 8, 2004 | 12:56 AM
mmfrog72's Avatar
mmfrog72
hceptj did a great job with the photos and instructions! But you need to flip back to page 12 and read the thread by "itlkick" on 2/17/04! He'll keep the job on the lighter side for ya!
Old Mar 8, 2004 | 10:23 AM
Phil056's Avatar
Phil056
mistercmk,
For the driver's side I had to pop off the fuel rail and move it to the side, and then took a deep breath and dug in . Hope it went well if you did them already.
Old Mar 8, 2004 | 02:31 PM
MisterCMK's Avatar
MisterCMK
Thanks guys, I was hoping I wouldn't have to remove the fuel rail, but oh well. I'll keep ya posted.
Old Mar 8, 2004 | 04:40 PM
Sigmund's Avatar
Sigmund
I just finished the project last weekend and didn't have to remove any fuel components. I did remove the two screws holding the drivers side rail to the manifold however, and that gave me enough play to get in there. For that last one I had to use a nut driver coming straight in from the top (snaked behind a hose I think) and then of course since there is no way to grab ahold of the driver with your hand, I used a vice grip on the driver handle to bust it loose and then just gradually worked it out and back in the same way.
Hope that helps!
Just don't do what I did on #3 on the right and think that my ratchet swivel was what was binding up until the bolt snapped off! Now that was fun to fix!
Old Mar 9, 2004 | 12:41 AM
BJWALL's Avatar
BJWALL
Angry
Well guys, I just changed a co-workers plugs in a 97
this weekend and what a Real pain in the butt, On the
drivers side I removed the two screws holding the fuel rail
and I tried like hell to remove the Quick Disconnect couplings
and could not get them off, I had the metal disconnect tool,
2 different types of the plastic ones and nothing happened.
With the little play in the fuel rail that I did have I was able
to snake in and remove the screws, The COP under the
feul pressure regulator gave me a little problem due to the
regulator being in the way.
To make matters worse that #4 COP came off without the
rubber boot !! The boot was stuck in the well and ofcourse
I could not get a good grip on it with my hand due to the
tight clearance. After 30 min or so I was able to get the needle
nose in there and pull it out. The #3 cop was stuck and took some extra effort to get it out. I checked the coils w/my ohmmeter
and they all checked out the same .6-.7 ohms on the 3 ohm scale.
I did not notice any antifreeze or liquid on the #3 or #4 COP.
After All that the thing still has a misfire but is running a little
better.
