How much nitrous can a mostly stock engine handle.
Old Mar 7, 2004 | 06:54 PM
moore89's Avatar
moore89
I have a 77 460 in my 67 f100 and I was wondering how much nitrous oxide it can handle. The engine as far as I was told was rebuilt within 40,000 miles ago. The only mods it has are, Holley 750 4bbl vac. secondaries electric choke carb, Weiand stealth dual plane high rise intake manafold, hedman hedders, dual 2.5" exhaust and the timing advanced 12 degrees.
Old Mar 7, 2004 | 07:44 PM
moore89's Avatar
moore89
anyone? Dose anyone know if it might be able to handle a 100 hp or 125 hp wet system with fuel selonid (sp?) hooked up to a nitrous enrichment tank with C16 fuel
Old Mar 7, 2004 | 11:19 PM
FordPickup460's Avatar
FordPickup460
I personally wouldnt do it. A motor like a 460 has enough power being naturally aspirated.
Old Mar 8, 2004 | 04:51 AM
DeenHylton's Avatar
DeenHylton
It should be able to handle 100-125 HP kit but I wouldn't go above that.
Dependng on what your compression ratio is you shouldn't need C-16 fuel...that's overkill. Most nitrous Mfg's recommend retarding timing 2 degrees for every 50 HP increase. If your running under 9 :1 compression you probably will be O.K. by retarding 2-4 degrees and running premium. If you get detonation (check your plug readings) then add some 100 octane low lead aviation gas...it's way much cheaper than racing fuel.
Deen
Old Mar 8, 2004 | 08:48 AM
classic79's Avatar
classic79
Assuming you have a typical non-performance rebuild you probably got low comp. cast pistons. If thats the case just take Deen's advise. You should not have any problems at that level if you are careful to make sure you avoid detonation.
DeckedoutF150
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
18
Feb 14, 2008 12:52 PM
matts77f100
Dec 21, 2007 07:11 AM
dmc919
Sep 12, 2006 05:15 AM
cowboy4x4
Jun 21, 2006 08:10 PM
fordtruckin
Dec 4, 2002 09:47 PM
