They are not hard, do you have the trailer package already? If you do there should be a plug under your dash. This is for the brake relay. 190$ is not that bad, if you require it all.
IE relay, wire, trailer fuse relay, outside plug, labor. Your best bet is to get a factory kit. Ford will have it all, and you will not have to cut a wire. NOTE* Because of the duel light system (yellow sig/red brake)*. A friend of mine wired his up with an after market one and his lights don't work, then his brakes came on when the signals were used.
I bought mine new, trailer package installed. So all I had to buy was the short wire from the plug to the relay. Then wire relay to the trailer brakes. Total time 40-60 mins. The biggest pain was pulling up the carpet and mounting the 6 wire plug on the hitch.
I hope this helped.
The trailer brake on my 97 was part of the package when I bought a Trail Lite Bantam B19 almost 3 years ago. The tech had a hard time. It took him 3 hours, but that included the entire trailer wiring/harness/plug. Last month I bought one form my Expedition: $79, Some kind of adapter: $15, Labor: $60 for a total of about $179 including tax.
