Fuel pump testing
Old Mar 7, 2004 | 09:30 AM
dtpax's Avatar
dtpax
Lightbulb Fuel pump testing
Does anyone here know how to test a fuel pump for a '90' F150 truck?
Old Mar 7, 2004 | 06:14 PM
RVMAN's Avatar
RVMAN
what do you want to test? pressure? flow? to see if the pump is running? What is the symptom(s) you are seeing with the veh? is this a in tank pump or the frame mounted one? There are different checks depending on what/where the problem is. One thing you can do is search the threads for "fuel pump" / "fuel pressure" and there are several areas covered. Good luck!!!
