First oil change.
Old Mar 10, 2004 | 06:11 AM
ferbm's Avatar
ferbm
Not that this adds any thing, but the filter kicked my *** for about 30 min. too. I have the 15 sided filter wrench and it just refused to work.. ..untill I wrapped the filter flutes with two passes of masking tape and a shop towel. I then tapped the filter wrench on.. ..not too hard! There are breakables all around. Even then, with good bite, I damn near ruptured my spleen getting that thing off! Felt good once it was done. I really like the spill diverter over the chassis too. Nice touch Ford.
Old Mar 10, 2004 | 08:12 AM
RX 1 Liter's Avatar
RX 1 Liter
After fighting, swearing, blooding knuckles, and cutting my forearms on the fan blades that SOB came off. To help a little I removed the air intake shroud and that gave me a little more leverage.
Old Mar 10, 2004 | 11:35 AM
fordguy61mi's Avatar
fordguy61mi
The screwdriver trick does indeed usually work although it can be quite messy. I found a "ratcheting" type of filter wrench in a parts store that works really well, too.
Old Mar 10, 2004 | 11:46 AM
mikelehmann's Avatar
mikelehmann
Mine was the tightest filter i ever had too take off. i used the band type. that thing didnt let go till more than half a turn wow
Old Mar 10, 2004 | 11:47 AM
mn 6.0's Avatar
mn 6.0
Seven quarts? You might want to drain out couple. I think it takes 6.5 with a filter.
