Battery/Charging problems
Old Mar 6, 2004 | 10:19 AM
cds's Avatar
cds
Hey guys I have got one for you, my 86 in my signature is having some battery or alternator problems. The truck sits alot but this problem just started and it has been quite warm here lately so I know it is not a cold issue. I can jump it off after it sits for a week and after it runs for a while it will start after normal use. I just had the battery checked at Advance and they said it was just showing low charge, no surprise there. I checked the voltage with it running and with no accessories on it shows about 14.2 when I turn the A/C on it drops to about 13.2, I have checked the battery connections and they are tight. I am just wondering it the alternator is on its way out. Does this thing have a seperate voltage regulator? I know on my 88 mustang 5.0 it was built into the alternator. Thanks, Dan
Old Mar 6, 2004 | 10:38 AM
melisa's Avatar
melisa
On my 86 with a 460, I believe that the alternator has an internal regulator. If you take it off, and take it to an advance or whoever, they can test it for you. Double check your cables for a bad ground/connection and/or corrosion. Before I bought my truck the previous owners went through 4 starters, and the only thing wrong was 17 year old ground cables.
Old Mar 6, 2004 | 04:59 PM
Chugalug's Avatar
Chugalug
Check the alternator belt and see if it is tight.
Old Mar 6, 2004 | 05:02 PM
bremen242's Avatar
bremen242
Actually, in '85, ford started using internally regulated alternators. some trucks got them, and some had the old standby-the externally regulated ones. By 86, they all should have the internally regulated ones.
Old Mar 6, 2004 | 10:04 PM
cds's Avatar
cds
Well, the alternator checked good but since I had it off, and it was 19 years old, I decided to replace it anyway. So far so good. The new one does not drop but to 14.2 with the a/c and lights on and runs at 14.5 with them off. The test will be letting it sit and trying it next week. Thanks for the advice. Dan
Old Mar 15, 2004 | 08:10 PM
cds's Avatar
cds
I should have know that would have been too easy. I checked the voltage on the battery on Sat. and it was down to 10.2, it started but barely. I turned it off and put a meter on it and started checking fuses. The only fuse that seemed to have any effect was the one for the interior lights, dash lights, according to the Haynes manual anyway. The lights are not staying on when the door is shut and I have not found any loose wires without tearing the whole dash apart, anyone have any ideas?? I checked all the ground wires I could find and all are tight.
Thanks, Dan
Old Mar 16, 2004 | 05:49 AM
justshootme84's Avatar
justshootme84
I'm having a similar problem on my 84 Bronco. I think it may be the battery discharging on it's own, probably has a bad cell inside it. When they get close to two years old, alot of them just won't hold a charge. Another truck I have was sitting for a few months, and it cranked right up this week. The Bronco will need a jump if I don't drive it for 3-4 days.
Old Mar 16, 2004 | 08:04 AM
Slade901's Avatar
Slade901
Typical battery lasts 2 - 3 years. So, it might be time to replace the battery.
Old Mar 16, 2004 | 10:14 AM
mchild's Avatar
mchild
Get the battery fully charged and then have it checked again and make sure they do a load test on it. Auto batteries can only deep cycle a couple of times before they are shot.
If the battery checks out then the next step is to find what is drawing on the battery when the motor isn’t running. To do this, remove the ground cable from the battery and put a voltmeter set on amps between the battery and the cable. Anything over about .5 amps is too much draw and means that something is draining the battery.
To find it you need to pull one fuse at a time and re-check the draw. When the circuit that is causing the problem is found the amps will drop. Then you know what to track down – something in that circuit. Things like glove box lights and such are frequently the culprits.
Good luck,
Mark
Old Mar 16, 2004 | 04:05 PM
cds's Avatar
cds
Thanks for the tips guys, I will get on it as soon as I can find the time. Dan
Old Mar 17, 2004 | 12:09 AM
DanMan7's Avatar
DanMan7
Yeah I think I might have a dead cell in my battery. When I put it on a battery charger it never gets fully charged (only like 90% and stops there). Sounds like it has a dead cell. It still shows around 14 volts. I was first thinking I didn't have a strong enough alternator, but I think it's the battery. It's almost 2 years old, so it might be time to replace the battery.
72camperspecial
May 28, 2013 09:12 PM
npccpartsman
Escape & Escape Hybrid
13
Jan 10, 2011 09:08 AM
phoneman91
May 6, 2010 04:22 PM
avator
1997 - 2003 F150
13
Dec 1, 2008 10:49 PM
josh390
18
Nov 8, 2008 04:03 PM
