Sponsored by: Auxito
Power Mirror Switch Replacement??
Old Mar 5, 2004 | 08:03 PM
cschroth1's Avatar
cschroth1
Question Power Mirror Switch Replacement??
Hi,
I recently bought a 1997 f-150 xlt f-150 with the 4.6L motor.
The power mirror switch only works in two directions on both sides?
If I was to replace the switch,How do I get it out?Also do I need to go to the ford dealer for this part?Thanks
Old Mar 6, 2004 | 10:10 AM
prcrboy's Avatar
prcrboy
Switch pops out with a little force and it will probally be an oem. However, check local salvage yard. I bought window replacement buttons at one for pennys on the dollar compared to new ones.
Old Mar 10, 2004 | 07:35 PM
maharris3's Avatar
maharris3
I had the same problem and it was an easy fix once I bought the new switch from Ford. I don't remember the cost but I would recommend going with the OEM part.
Old Mar 11, 2004 | 04:54 AM
riverguy79's Avatar
riverguy79
It is actually super easy (and cheap) to replace - at least for my 2002 F-150. You can pop the old switch out with a flat blade screwdriver and then just disconnect the wiring plug. A new switch was about $20 at my local dealer. Just plug the new switch in, pop it in to place and you are good to go.
connork
Apr 7, 2015 07:59 AM
narrowfarm
Oct 16, 2014 09:22 PM
Dozier
2004 - 2008 F150
Jun 27, 2014 11:28 AM
BrassMonkey
2009 - 2014 F150
Jan 26, 2014 01:07 AM
86step
2009 - 2014 F150
Aug 9, 2013 06:52 PM
