Radiator
Old Mar 5, 2004 | 07:55 AM
Chumbucket's Avatar
Chumbucket
Radiator
How do you tell how many row's on the radiator?? This is 92 150 300 with MT/AC. OEM Thank's
Old Mar 9, 2004 | 01:15 PM
ASH's Avatar
ASH
If I understand your question, you are asking how many cores are in the radiator. If your truck did not come with a towing package, it is probably a single core. If my memory serves me right, a single core should be around 1-1/4" thick. This is measured across the fins, not the surrounding case. A double core is approximately twice as thick, 2-1/2". If you remove the cap and lower the level of the anti-freeze, you should be able to see the cores (holes) in the radiator.
