gas milage ???
Old Mar 4, 2004 | 08:02 PM
thecowboy's Avatar
thecowboy
gas milage ???
hey there
im just wondering what a reasonable gas milage is for 1980 F-100 300 I6 C-4 3 speed no overdrive auto. (I think thats the problem) I get around 9 to 11 mpg.
Whould a C-6 w/overdrive help.
THANKS
Old Mar 4, 2004 | 09:39 PM
thecowboy's Avatar
thecowboy
bump
Old Mar 4, 2004 | 11:23 PM
plowpusher's Avatar
plowpusher
that sounds pretty low is your choke opening all the way? have you checked float level a 300 w/o od should still get 15-18 if it's set up right in a 1/2 ton
Old Mar 5, 2004 | 06:34 AM
bremen242's Avatar
bremen242
It check the choke, and i'd see if the tailpipe is black. Most of the time you should get at least 14mpg. I did when I had a 1bbl on my truck
Old Mar 5, 2004 | 07:56 PM
doccamel's Avatar
doccamel
not if you have a 4.10 or 4.11 in the axels. 11 is fairly normal if they are geared that way. If not then do full tune,(plugs wires, cap rotor etc) and see what it does.
Old Mar 5, 2004 | 08:39 PM
bremen242's Avatar
bremen242
this is true, but I've never seen a factory 300 truck gear with lower gears than 3.55s, unless it was a HD truck
Old Mar 5, 2004 | 09:18 PM
doccamel's Avatar
doccamel
A freind of mine has an 80 150 4x4 300 4spd. that came from ford that way. It is rare but some were made. Mainly special order.
Old Mar 6, 2004 | 07:32 AM
bremen242's Avatar
bremen242
with 4.11 gears?
Old Mar 7, 2004 | 11:29 AM
thecowboy's Avatar
thecowboy
Thanks alot
not doing anything today so ill let you know how it went
